Hey guys,
my uncles computer started crashing or not booting a few weeks ago and since then I have it here to repair. Normally thats not a problem for me, but for some reason this one is kinda tricky.
Well actually I know the reason, I have no other AM2 board to test it with and the system doesn't power on anymore at all.
The system:
  • MSI K9N NEO V1.0
  • 2x 512MB DDR2 RAM
  • AMD Athlon X2 (don't know the exact one - somewhere above 2GHz)
  • Ati Radeon X1300
He has it for 4 years now and hasn't been using it very much (booted approximately 3-5 times a month and is kept in a clean environment so no dust in the case at all).
Thats why I'm not so sure about my conclusion.
What I've done so far:
  • I reseated everything and powered it - no success.
  • RAM is in the right config and worked for the past 4 years just fine.
  • I checked the PSU and even swapped it with another working one, still no power on.
  • I also checked the power switch and shorted the pins but that also didn't move a thing.
  • Of course everything was unplugged except for 24pin power-brick and the power switch.
The most awkward thing is that there is not a single LED glowing and even the fans don't tick like they do if there is a short somewhere and the PSU shuts down after 1 second.
So my conclusion is that the MB is dead.
What are your thoughts?
Thanks in advance!
Kind regards,
Trek
Bitfenix Phenom M White | ASUS RoG Maximus VIII Gene | Intel i7 6700K @4.6GHz | HyperX Savage 2800MHz CL14 DDR4 16GB | EVGA GTX1080 SC | Intel 750 Series PCIe SSD 400GB | EVGA SuperNova G2 550W | Windows 10 Professional x64 | Logitech G900, Corsair K70 RGB MXbrown O-ringed, BeyerDynamic DT880 (600 Ω) on Fiio E10K & Samson Meteor | Dell U2715H 27", Samsung SyncMaster P2450H 24", Samsung SyncMaster 931BF 19" | DIY Ambilight
https://linustechtips.com/topic/89751-old-am2-system-doesnt-power-on/
Yea either Motherboard or maybe even CPU
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
Hey guys,
The system:
  • MSI K9N NEO V1.0
  • 2x 512MB DDR2 RAM
  • Ati Radeon X1300
Thanks in advance!
Kind regards,
Trek
well, think its time for an upgrade.
I have a OLD Am2 system too(i dont use it, itd my old gaming rig". But i dont use it but it works fine:D but extremly slow. like 3-4 min startup... Wha´tch the specs on my profile
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
Never like Athlon. Bad old days. :angry:
NO IT WAS AWSOME!
Well he doesn't even have an internetconnection and needs it only to read some PDFs from work or write documents (OpenOffice 2.3 :P) to print for taxes etc. ;) so no upgrade required
