My search for that one beige case nobody likes isn't going so well for my retro build. So this is my motherboard: http://support.gateway.com/s/MOTHERBD/INTEL/4000532/4000532nv.shtml
And these are the cases I'm thinking about:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811233116
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4487998&CatId=1843
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/89741-will-it-fit/
Well the motherboard is an ATX and the cases support ATX motherboards so I don't see why not :P Also the GIGABYTE looks better in my opinion.
https://linustechtips.com/topic/89741-will-it-fit/#findComment-1213149
dont see why not it says its atx form factor and it only has 5 pci expansion slots that is one weird mobo what are u going to use it for? what socket is it? is the cpu soldered on the board?
It's one of the old slot Pentium 3's. "Only" 5 Expansion slots? Only?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/89741-will-it-fit/#findComment-1213156
I feel stupid. The case will need 7 PCI expansion slots for it to fit. Wish I woulda realized that earlier.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/89741-will-it-fit/#findComment-1213158
clearly im missing something because the cases u showed had 7 slots and the mobo only has 5 i dont get it :S
https://linustechtips.com/topic/89741-will-it-fit/#findComment-1213166
I think he has 15 expansion slots..........
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
https://linustechtips.com/topic/89741-will-it-fit/#findComment-1213168
AGP=1
5x PCI=5
ISA=1 that the bottom PCI slot uses.
That's 6, then the bottom one for a little extra room.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/89741-will-it-fit/#findComment-1213169
and the cases u showed me had 7...
Yeah, so it will fit fine, since I want a little room in the bottom. Just that hit me like a brick halfway through class.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/89741-will-it-fit/#findComment-1213185
Oh, if you had 133 MHz FSB instead of 100 MHz you'd buy an adaptor to socket 370 :(
Anyway I prefer the gigabyte one.
I'm keeping this thing as original as possible. The original video card, motherboard, processor, and RAM. Just I need to find a good hard drive for it, and another fan for the processor, since it used to rely on the power supply fan for cooling, and my fan sounds like it's dead.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/89741-will-it-fit/#findComment-1213244
Samsung Spinpoint IDE HDDs are nice, but won't be very usefull with Ultra-DMA33...
I have one in my old Dell. xD Might just steal it, or my trusty old Barracuda ATA IV, but I don't think I'll use the Barracuda, since it's on its last leg.
I might be able to find a Quantum Fireball, or a Bigfoot. It came with a LCT15 15GB one.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/89741-will-it-fit/#findComment-1213358
You certainly can try to get it to fit. But after looking at the standoff locations on the Tabor3 and comparing it to today's ATX standoff location, natively the board won't fit as some of the standoff holes don't line up. Unless I'm missing a hole or two.
If you want this board to fit into a modern case, you might have to mod the case for the standoff holes to line up.
It's worth trying out. If it fits into today's standard without modding, then I'm wrong!
Good luck!
https://linustechtips.com/topic/89741-will-it-fit/#findComment-1213429
Yey Quantum fireball... I've the LCT 08 from a old Slot Pentium III PC... still working but when it starts the noise is terrible :P
The one I want to rebuild came with a LCT15 15GB I think.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/89741-will-it-fit/#findComment-1213457
Good luck!
Which holes, exactly? I got it to squeeze into the case ZEUS is in. If it's for the P3, that broke, and is no longer there.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/89741-will-it-fit/#findComment-1213961
