What does it mean when a motherboard does not support DirectX 12?
Solved by AT0MAC,
i don't really seem to find the same information as you, is it not this board or am i mistaken?
either im not awake or i can't find anywere on msis product specs that the board should have anything to do with direct x.
if you have found it somewhere it could be because msi states that it will support 8th gen celeron cpus, not sure but there might be variants of those that dont support dx12 and then msi have stated it like unsupported instead of giving false hope
but like the rest have said, as long as you just get a separate newer gpu and windows 10 then you are golden
