Why does my C key only work when shift is down?
So after playing around with my new mouse and playing with macros I set a macro to c so I could use push to talk.
But now the c key will only work if the shift key is down and I've been using cap locks and shift to right lower case c what do I do
I'm using the corsair strafe with the corsair utility engine software
This sounds like the Corsair macro software is somehow *catching* the regular c presses for some reason. I'd save your macros out of directory and than delete all settings and see if that helps.
PSU Tier Ranking List
Ryzen 5 1600x|ASROCK                      |16GB DDR4 3400Mhz Corsair Vengence   | (partial build in progress)
FX-8350 AM3+| ASUS M5A990FX V1 | 32GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H100i v1
FX-8120 AM3+| ASUS M5A990FX V2 | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H80i v1
I5-2500K LGA  | ACER MOBO??         | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 860 PRO | Win 10 64 Pro | EVGA 750W G PSU | EVGA 970 SC 4GB | Corsair H80i v1
I've deleted all the macros from the corsair engine I originally made my razor synapse software to use push to talk from my mouse by making it push c for me so far I've deleted the macro from the mouse
Did you actually have the software (both preferably) set to a factory-first install settings reset? Also try uninstalling the software 1 by 1 so you can pinpoint the software that maybe creating the issue.
27 minutes ago, STRESSMASTER said:
Did you actually have the software both preferably do a factory first install settings reset? Also try uninstall you pinpoint the software that maybe creating the issue
Idk if it makes a difference but the on screen keyboard doesn't like the c Key either
That means it is almost a guarantee that it is a software *catching* that key and trying to use it as a macro start key. I'd uninstall each macro software 1 by 1 and try to see what one is doing it.
Is there a way to clear data from synapse because my c key only works once the software is reinstalled but then it logs into my razor account and syncs from cloud and i loose my c key?
