I'm planning on building a new PC for Christmas which my parents are going to put some money towards it.  It will be for 1080p gaming and personal use.  I wouldn't mind overclocking it and having a bit of a play around with it but it wont be anything major.  I willbe looking to crossfire sometime in the future when I need a little bit more performance.  I also prefer a smaller form factor like Micro-ATX so i can take it to friends places more easily.  This is why I went with the Intel route as they have more options. I need a OS and would prefer Windows 8.
I have got a list of parts which i think is good for what i want but i need to cut the price down too around $1000(AUD). As i still need a monitor and keyboard.
http://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=216237&action=wish_lists
This is the list of parts that i have come up with so any tips on cutting the price down a little without sacrificing too much performance.
Also about the Prodigy M cooling, what configuration of fans do you recommend?
Any help would be much appreciated.
https://linustechtips.com/topic/89690-first-pc-need-help-australia/
Are you open to other Aus shops or are you limited to pccasegear?
Would recommend the CX750 Modular over the non-modular, just for cleaner cable management.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=15_354&products_id=22419
Edit: And also for gaming I would go for Windows 7 Ultimate 64bit.
Most games have compatibility issues with Windows 8.
I was looking at that one but longer graphics cards in this case can block one of the rows of modular connectors.
P.S. Windows 7 Ultimate is about $95 dollars more which doesn't seem worth it.
No game has any compatability issue with windows 8, windows 8 is proven to perform better on games. Windows 7 'ULTIMATE' Wouldn't be worth it for sure
Only changes I would recommend would to get a modular PSU (for reference: http://www.pccasegear.com/index.php?main_page=product_info&cPath=15_995&products_id=15350 I got my PSU for around $120 so look around and you should find nice deals) and get a different hard drive, the Barracuda has this annoying spin up sound and is on the loud side (compared to a WD Green, WD Black and some other random hard drives I found) - a WD Blue might be the best choice since it is from a reputable brand/known to be good for it's price.
EDIT: After some thought, I think the PSU is a nice choice if you're not going to install a windowed side panel.
i5 4670K | ASUS Z87 Gryphon | EVGA GTX 780 Classified | Kingston HyperX black 16GB |  Kingston HyperX 3K 120GB SSD | Seagate Barracude 3TB - RAID 1 | Silverstone Strider Plus 750W 80Plus Silver | CoolerMaster Hyper 212X | Fractal Design Define Mini
The Black is quite louder then the barracuda. I've had a good number of barracudas myself and I don't think they're that loud. You might just have a bad drive.
PC case gear but if you can recommend another reliable cheaper option I'm open to suggestions.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
Edits: http://au.pcpartpicker.com/p/2lG6h
Your budget is too small to allow for future crossfire.
Weird.... then again I do have PC sitting right next to my head (it sits on my desk since it's small enough to) - to be honest the noise is bearable :3
My friends WD Black is stupid quite considering it's a WD Black, I was legitimately surprised at how quite it was when I had built his rig and played around with it.
