Script to ping and reset connection
Go to solution Solved by DumbTrollface,
Found out that ping does indeed return an exit code and that you can check the exit code of the previous programm by using %errorlevel%.
@echo off
ping router
if %errorlevel% NEQ 0 (disable_device
	timeout /nobreak /t 10 //Wait 10 seconds
	enable_device
And after some testing it seems to work.
EDIT: If someone is curious: I use devcon for disabling and enabling the device
Hey folks,
I have the problem that I'm using powerline for a wired connection since my wifi is quite slow. But since my home is pretty old the powerline adapter keeps losing connection roughly every hour.
I do have wifi connected but windows still tries to use the wired connection for a few minutes even though it says that it has no connection over ethernet but that wifi works fine.
So my question is: Is there a way to force windows to use both simultaneously or switch immediately?
And if not: I already have a script written that resets my ethernet port (which fixes the problem). Can I continously ping my router and if it loses connection do the reset?
So something like
while (true) { // infinite loop
	int ping = ping.exe //use ping.exe to check connection
	if (ping == ping_failed) {
		reset_ethernet();
	wait(1000);
using cmd
Edited by DumbTrollface
fixed typo
https://linustechtips.com/topic/896880-script-to-ping-and-reset-connection/
26 minutes ago, DumbTrollface said:
Hey folks,
So something like
		reset_ethernet();
	wait(1000);
using cmd
You could use Task Scheduler to run that script as often as you want (every 1 second, 5 seconds, 30 seconds, 5 minutes - whatever).
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
Just now, wonderforest said:
Just unplug the ethernet wire ?
First of all it's pretty hard to access and secondly I don't really have the time for that. I need my internet for work and can't have any downtime.
And if you mean to just continue using wifi: I would go from ~25k down to ~2k down. So that's not really an option
1 minute ago, DumbTrollface said:
But I only want to do that if the connection is actually down
Do what? Run the script?
You write the script to check the connection (eg: ping), and if the ping fails, the script executes an action (eg: reset ethernet adapter).
The Task Scheduler continually runs the script, to check the connection.
It would only reset the connection IF a ping test failed.
With that in mind, you might need to modify the script to make this work.
I guess, if your existing script works as-is, you could just put a shortcut to the script into your startup folder, and start it when you turn your computer on.
That's what I want. My question is how I check the connection using ping. Does it return a value?
@echo off
ping router
	enable_device
