I dialed in 39 for the multiplier to run it on 3.9ghz and I left the voltage on auto.
I already tested it via Aida 64 and run multiple Cinebench, no crashes.
But I panic a bit when a I saw the core voltage reading on CPU-Z, Its running 2.0v even on idle, I checked CPUID on AIDA64 but its says the voltage where 1.384 on idle and hitting 1.4v on load..
whats the issue here?check the attached image
Ryzen  5 3600 | ASUS Strix B450i Strix | G-Skill Trident Z RGB 16gb 3200mhz
Gigabyte RTX 2070 Super OC | Samsung 970 EVO Plus 500gb | NZXT H200i | NZXT x52 | Corsair RM650x
https://linustechtips.com/topic/896802-help-ryzen-5-1600-overclock/
I think it might just be a bug in CPU-Z, most CPUs can't handle more than 1.5v.
STOP!
It's also not 2V, if it were 2V your chip would be dead
Just manually set your Voltage to 1.4V preferably lower if you can
Also what motherboard?
probably just a bad read from CPU-Z. if it was really pulling 2V it really wouldn;t be stable i think :P
1 minute ago, Streetguru said:
STOP!
Asus Strix B350f
i just doubled check with hwmonitor, it has the same reading as cpuid on aida64,probably a bad reading on cpu-z
I once ruined a perfectly good FX 8320 by leaving the voltage setting on auto on some Asus FX990 board...
Never do this on a substantial overclock. Just manually search for the lowest settings your chip can handle.
52 minutes ago, Morgan Everett said:
Don't use auto voltage when overclocking.
im still looking for the lowest it could go, I noticed on my first runs of Cinebench the voltage is boucing from 1.37v to 1.4v max I dunno why..It seems that if the temps are low it will add voltage I'm not sure if this is XFR
FX chips can almost survive whatever voltage you throw at them so long as you keep it cool.
Just go for 1.375V
Just go for 1.375V
its now stable at 1.375v but still its fluctuating upto 1.406v,its that suppose to happen?
Check your LLC settings if you have any, it may be set to put more voltage as you go under load.
Thanks man!
