The height for this cooler is 160mm, which is rather big.
For some cheap solution you could try things like (prices are under 50 euros in the netherlands):
Cooler Master Force 500
Cooler Master N300
" " K280
" " Elite 430
Fractal Design Focus G
Fractal Design Core 2300
PC Specs: Intel Core i7-8700k - Asus ROG Z370 MAXIMUS X HERO - 2x8gb Kingston Predator DDR4 3200MHz - MSI GeForce GTX 1080 Ti gaming X Be Quiet! Dark Rock Pro 4 - Samsung 850 PRO 256gb - Samsung 850 EVO 500gb - Seagate Barracuda 2tb - Fractal Design Meshify C - Asus PCE-AC56 - Be Quiet! Straight Power 10 CM 700W.
Peripherals: Corsair K70 LUX - Steelseries Rival 310 - Dell S2417DG - Beyerdynamic Custom One Pro - Audioengine D1.
If you want to search for yourself go to:
https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=case&ignorear=0&N=100007583&isNodeId=1
Go to: Max CPU Cooler Height Allowance
Pick over 150mm
Check all boxes with a number bigger than 160mm
Et voila, there are all your case options :)
Good luck!
2 hours ago, david97 said:
So i recently bought a Scythe Ninja 3, and it's not fit into my pc's case. Do anyone uses this cooler around here? Whit waht case? Do you know any cheep solution?
Thanks for your answers!
