Hey guys, I'm in the market for new headphones because I absolute hate my razer kraken and it can just die in a f**king fire its uncomfortable as hell and shouldn't even exist. I need something which is USD$65 ish and I am going to use it mainly for gaming but also music. I listen to different types of music so just need something decent. I don't need a mic as my laptop has one built in. I also need closed headphones as I don't want to disturb my family members in the night when I'm staying up late at night. Also, I'm going to use integrated audio so nothing too over the top.
ASUS ROG G75VX
Intel i7-3630QM 2.4GHz/3.4GHz Turbo | Nvidia GeForce 670MX 3GB OCed to 736MHz | 750GB HDD | Windows 8.1 | 24 GB 1600MHz RAM | Razer Goliathus Medium | Logitech G400s | Razer Kraken/ JBL J22 | Corsair Vengeance K70 Cherry MX blue
https://linustechtips.com/topic/89581-headphone-recommendation/
Some good Sennheiser's
Specific models?
ASUS ROG G75VX
https://linustechtips.com/topic/89581-headphone-recommendation/#findComment-1210859
I will look, I got the 280 HD Pro's for $100, They might be open though. I will look. @iceballfunela
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
https://linustechtips.com/topic/89581-headphone-recommendation/#findComment-1210861
Do you need noise cancelling?
Nope, just need something that won't leak much noise, some is okay, but not too much.
ASUS ROG G75VX
https://linustechtips.com/topic/89581-headphone-recommendation/#findComment-1210871
How long would you have to wait to double your budget. I think you would be better off in the long run than buying something in your price range right now. This is what you should be aiming for
http://www.newegg.com/Product/Product.aspx?Item=9SIA1J20MX9760
Rig: i7 2600K @ 4.2GHz, Larkooler Watercooling System, MSI Z68a-gd80-G3, 8GB G.Skill Sniper 1600MHz CL9, Gigabyte GTX 670 Windforce 3x 2GB OC, Samsung 840 250GB, 1TB WD Caviar Blue, Auzentech X-FI Forte 7.1, XFX PRO650W, Silverstone RV02 Monitors: Asus PB278Q, LG W2243S-PF (Gaming / overclocked to 74Hz) Peripherals: Logitech G9x Laser, QPad MK-50, AudioTechnica ATH AD700
https://linustechtips.com/topic/89581-headphone-recommendation/#findComment-1210874
Save you some $$$
HD 203 http://en-us.sennheiser.com/studio-stereo-headphones-closed-hd-203
https://linustechtips.com/topic/89581-headphone-recommendation/#findComment-1210884
Well, I don't know how long I'll have to wait... In SGD its 239, its a little expensive for me :/.... 1 question, what is the impedence?
ASUS ROG G75VX
https://linustechtips.com/topic/89581-headphone-recommendation/#findComment-1210886
You could give the JVC HA-S500 a look. Keep in mind they are on ear though. Supposed to have pretty good sound quality for the price.
Isn't JVC like out of business or something?
ASUS ROG G75VX
https://linustechtips.com/topic/89581-headphone-recommendation/#findComment-1210899
No, where'd you hear that from? lol
Idk actually...
ASUS ROG G75VX
https://linustechtips.com/topic/89581-headphone-recommendation/#findComment-1210910
I just looked it up and it looks like they merged with a company called Kenwood a while back, so I think they're now called like JVC-Kenwood or something, maybe thats what you're thinking of.
Yeah, I think so.
ASUS ROG G75VX
https://linustechtips.com/topic/89581-headphone-recommendation/#findComment-1210927
Impedance is a tricky thing when it comes to headphones. I don't fully understand it but I know having a higher impedance doesn't necessarily mean better quality. What it does mean though is that the headphones will require more power to drive them (need an amplifier or they will sound quite). You can have low impedance headphones and they can still have cracking good quality. Generally much higher end headphones ($300+) tend to be high impedance headphones.
https://linustechtips.com/topic/89581-headphone-recommendation/#findComment-1211020
+1 on the ATH-M50's, after a bit of a burn in they are amazing headphones, If you time it right and with the holidays coming up it'll work look at amazon for them i've seen them for around $100 which is about half their cost normally.
CPU:i5-3570k OC'd to 4.0 MOBO: MSI Z77A-G41 GPU: Asus 660Ti 2Gb OC Case: NZXT Source 210 Black and Windowed RAM: Kingston HyperX Black Series 8GB Storage: WD 1TB Caviar Black, 3TB WD Green, 120GB Kingston HyperX CPU Cooler: CM TX3 PSU: EVGA SuperNOVA 750W OS: Win 7 Perf: Corsair M65, Acer S220HQLAbd 21.5" Main with 17" Secondary, a Corsair K70, and ATH-M50's.
https://linustechtips.com/topic/89581-headphone-recommendation/#findComment-1211180
