This is a $2000 USD build for mainly gaming but also, maybe some editing in the future. I intend to add another GPU in the future so that is the reason behind the large PSU. I have an OS in it and will probably OC (still a little undecided). I want it in the Prodigy M so I might not OC because of airflow issues. No other peripherals. I have put them into a PCpartpicker list even though I will be buying from Newegg
http://pcpartpicker.com/p/2luuA
Thanks
EDIT: Changed the H80i to Noctua Nh-D14, New link has been inserted
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
https://linustechtips.com/topic/89576-final-thoughts-on-2000-build/
overkill psu unless you plan on adding another gpu
I do plan are adding another one in the future. Will change OP to include that.
Why only H80i? If you're going that cheap, just get a NH-D14.
I am worried about height clearance. also, that would be a little louder than the H80i I would think. I went full retard
The NH-D14 is 9386152745610823740982572097409823460982357098 times quieter than the H80i. No idea what you are talking about.
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
Noticed you're going with an Asus Maximus Gene board, good choice!
ROG FTW
Not a lot more to get the Blue Ray player then you know you can play HD blu ray discs and be futureproof, also look at a SSHD (hybrid) in the same size it again is best of both worlds and good for games and storage files.
got to love Asus components
The h80i isn't even quiet and is considered pretty loud.
@zxcvbnmmssdh
By editing, do you just mean game footage?
I wouldn't recommend the 780 Ti as it's a bad value.
Are you dead set on the Prodigy case?
@zxcvbnmmssdh
What I mean by editing is some game footage and maybe some just regular footage. Do you have another recommendation for a GPU. The reason I chose that is for the SLI down the road will b better and turn into the best value. Also, I want the Prodigy case so I can take it around easily. @Worth and I have some friends as well and we go to their houses and such and it will be easier in this case. Do you have another suggestion with handles and can be transported easily? I am going to go with the H80i most likely because I am worried that the NH-D14 will restrict airflow.
The NH-D14 shouldn't restrict airflow since it will be pushing air in the same direction as the case fans.
I'd recommend waiting for aftermarket 290's to see how they fare.
Another reason why the 780 ti is so appealing is g-sync coming up soon, Shadowplay, compatibility with the Shield, and the game bundle (it comes with AC3, Arkham Origins, and Splinter Cell Blacklist). I will most likely get the NH-D14 seeing that you got a 4.5 ghz OC on your CPU with that. Does it handle that OC well?
The cooler? It's great for oc's. My chip? Not so good.
You could get 4.5 ghz off of a 212 Evo depending in your chip.
AMD is coming with their own Shadowplay called Experience - Predator. I wouldn't worry about G-sync until it hits higher resolution ips panels. It's not worth going 1080p TN atm just for gsync especially wen you can already just push 60+ fps for most games. If you're getting the Shield, you don't have much choice but to go Nvidia but I wouldn't get the 780 Ti. It's a bad value. I'd go for the 780 instead.
