Need Help Upgrading Old PC
Solved by ElSeniorTaco,
I'm going to go with bad gpu on this one.
I know the 1000 series uses way less power, but you are able to pass post and get into windows off the integrated on the inspiron while having the 645 plugged in, which is a little fishy if we wanted to consider this a PSU issue.
Something just seems wrong about that 645.
And considering how much newer the 1050 is, and the fact that its working in this inspiron, I'm going to rule out compatibility as well.
I would send it back to the seller, as DOA.
