Uplay and Origin don't work after changing MAC address.
7 minutes ago, Santipro said:I changed the address in the Windows Device Manager. No ports were being forwarded to that address.
well it's obvious unspoofing it will fix it.
What I recommend is to use Multiple NICs. If you're trying to get a new IP assigned from the pool and you're plugged directly in without a router, then that's the best way. Even a few USB NICs will do the trick.
Really I recommend you get a few cheapo routers to do this or some kind of PF sense router with a few nics to rotate between
Or, assuming you're like on a dorm network or something at a university and you need to use a particular mac that's registered, spoof with one computer and bridge to this computer using a shared connection. I mean there's ways to do with virtual adapters and stuff, but this keeps it simple. I know some of those networks will auto ban routers. If a particular mac isn't what you need, again a few usb adapters.
