so umm y question is for ddr4 ram. what's the best ram speed. one should get.
example
8gb. minimum for games
12. being safe.
16 over kill
My Question is. for  Speed
there's  these Ram. speed my question is. Which one would be best. for games. 2400? i don't wanna overkill it. Because i have a Budget i only want the Safe option. and the minimum for games.
DDR4-2133
DDR4-2400
DDR4-2667
DDR4-2933
DDR4-3200
https://linustechtips.com/topic/894374-ram-speed-for-games/
3 minutes ago, trevrez said:
From your previous post it looks like you plan to get the R5 1600. If going Ryzen you will want to get the fastest RAM you can.
Don't have enough Budget. for the 3200.
100$ max for 8gb ram ddr4. can u please tell me the best/highest speed 8gb that i can get for 100$ max?
https://linustechtips.com/topic/894374-ram-speed-for-games/#findComment-11023969
8GB 3000MHz, $87.
https://m.newegg.com/products/N82E16820232419?ignorebbr=1&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker%2c+LLC-_-na-_-na-_-na&AID=10446076&PID=3938566
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/894374-ram-speed-for-games/#findComment-11023979
there's  Which one would be best
"depends"!
CPU: Ryzen 7 5800x3D | MoBo: MSI MAG B550 Tomahawk | RAM: G.Skill F4-3600C15D-16GTZ @3800CL16 | GPU: RTX 2080Ti | PSU: Corsair HX1200 |
Case: Lian Li 011D XL | Storage: Samsung 970 EVO M.2 NVMe 500GB, Crucial MX500 500GB | Soundcard: Soundblaster ZXR | Mouse: Razer Viper Mini | Keyboard: Razer Huntsman TE Monitor: DELL AW2521H @360Hz |
https://linustechtips.com/topic/894374-ram-speed-for-games/#findComment-11024041
Keep in mind that you'll be losing a lot of performance with lower speed RAM in CPU intensive games and apps, and even more so if you go for single channel.
i7 9700K @ 5 GHz, ASUS DUAL RTX 3070 (OC), Gigabyte Z390 Gaming SLI, 2x8 HyperX Predator 3200 MHz
https://linustechtips.com/topic/894374-ram-speed-for-games/#findComment-11024131
