Hello, so, whilst browsing ebay i stumbled upon an old 2x6 Xeon server for around 300 Euros, which gave me an idea of improving what i currently do. I have multiple processes for work running pretty much all the time I am at the pc, each consuming around 3-5% CPU on my 4690k OC'ed to 4.0 GHz(Let me know if theres a better way to measure that), around 500MB ram and barely any GPU at idle, and around double the CPU usage whilst focused. I know how multiple cores/threads affect rendering, but have not looked into its effect to multi-tasking. So, my first question would it even be worth doing such a project for my task?
2nd part - Whilst just looking at random deals on Ebay i remembered Linus's video on the 150$ server hardware gaming build, and as usual for enthusiasts, figured building my own would be cheaper, and more fun (if it actually is worth doing). The process is does use multiple threads, but most of its usage is the main thread. At this point, I've not put much research into it, and looking for a simple "Yes its a good idea" or "No its terrible" from someone more experienced, before doing more, but what would be more beneficial for this? More cores or higher clock speeds? For example, after a quick search on ebay, the L5638 with 6 cores and 2 GHz, or the X5450 with 4 cores and 3 GHz? Sorry for the broad question, but any input would be appreciated.
https://linustechtips.com/topic/894257-old-xeons-for-multi-tasking/
What are you doing? What are these processes?
These systems are normally loud and hot, will need new ram(but this ram is cheap) as well.
I have a few of these systems, just stoped using one as my server due to power usage(with l5630's).
stay away from anything 54XX or older, those are worse.
They really aren't that much faster than your i5, id probably spend you money on a ryzen system that will be faster and get you things like built in audio, usb3, nvme support, and other modern features.
I wouldn't recommend either of those. L5638 is a low power CPU and many LGA1366 4 core CPU's beats it easily in multicore performance. And X5450 is older generation (LGA775) and it is worse than most 4 core LGA1366 CPU's.
For dual LGA1366 workstation a Xeon X5670 (6 core, LGA1366) or higher would be ideal.
Intel Core i9-9980XE 18c/36t, Asus TUF X299 Mark 1, 128GB DDR4 3200MHz, Palit RTX 5070, 2TB 970 EVO Plus, 2TB SN570, 8TB HDD, Meshify 2
PC 2: AMD Ryzen 7 3700X 8c/16t, MSI X470 Carbon, 32GB DDR4 2666MHz, Asus GTX 1080 Strix, 512GB Samsung PM981, 1TB Crucial MX500, Fractal Define R4
Old PC: Intel Xeon X5670 6c/12t @ 4.40GHz, Asus P6X58D-E, 48GB DDR3 1600MHz, EVGA GTX 970 ACX 2.0, 500GB, 250GB & 120GB SSD, 10TB & 2x 4TB HDD, Fractal Define R5
PC 3: Intel Xeon E5-2690 8c/16t @ 3.3-3.8GHz, ThinkStation S30 (C602/X79), 64GB (4x 16GB) DDR3 1600MHz, Asus GeForce GTX 960 Turbo OC, 1TB Crucial MX500
Laptop: ThinkPad T440p, Intel Core i7-4800MQ 4c/8t @ 2.7-3.7GHz, 16GB DDR3 1600MHz, GeForce GT 730M (GPU: 1006MHz MEM: 1151MHz), 2TB SSD, 14" 1080p IPS, 100Wh battery
Phone: Samsung Galaxy S23 256GB Watch: Samsung Galaxy Watch7 44mm LTE
General X58 Xeon/i7 discussion
Some other PC's:
Some of the specs of these systems might not be up to date
Z77: Intel Core i7-3770 4c/8t @ 4.22-4.43GHz, Asus P8Z77-V LK, 32GB DDR3 1648MHz, Asus RX 470 Strix, 1TB & 250GB Crucial MX500 and 3x 500GB HDD
PC 4: Intel Xeon X5675 6c/12t @ 3.07-3.47GHz, HP 0B4Ch (X58), 12GB DDR3 1333MHz, Asus GeForce GTX 660 DC2, 240GB & 120GB SSD, 1TB HDD
PC 5: Intel Xeon W3550 @ 3.07GHz, HP (X58), 8GB DDR3, NVIDIA GeForce GT 640 (GPU: 1050MHz MEM: 1250MHz), 120GB SSD, 2TB, 1TB and 500GB HDD
PC 6: Intel Core2 Quad Q9550 @ 3.8GHz, Asus P5KC, 8GB DDR2, NVIDIA GeForce GTX 470, 120GB SSD and 500GB HDD
HTPC: Intel Core2 Quad Q6600 @ 3.0GHz, HP DC7900SFF, 8GB DDR2 800MHz, Asus Radeon HD 6570, 240GB SSD and 3TB HDD
WinXP PC: Intel Core2 Duo E6300 @ 2.33GHz, Asus P5B, 2GB DDR2 667MHz, NVIDIA GeForce 8500 GT, 32GB SSD and 80GB HDD
RetroPC: Intel Pentium 4 HT @ 3.0GHz, Gigabyte GA-8SGXLFS, 2gb DDR1, ATi Radeon 9800 Pro, 2x 40gb HDD
My first PC: Intel Celeron 333MHz, Diamond Micronics C400, 384mb RAM, Diamond Viper V550 (NVIDIA Riva TNT), 6gb and 8gb HDD
Server: 2x Intel Xeon E5420, Dell PowerEdge 2950, 32gb DDR2, ATI ES1000, 4x 146gb SAS
Dual Opteron PC: 2x 6-core AMD Opteron 2419EE, HP XW9400, 32GB DDR2, ATI Radeon 3650, 500gb HDD
Core2 Duo PC: Intel Core2 Duo E8400, HP DC7800, 4gb DDR2, NVIDIA Quadro FX1700, 1tb and 80gb HDD
Athlon XP PC: AMD Athlon XP 2400+, MSI something, 1,5gb DDR1, ATI Radeon 9200, 40gb HDD
Thinkpad: Intel Core2 Duo T7200, Lenovo Thinkpad T60, 4gb DDR2, ATI Mobility Radeon X1400, 1tb HDD
Pentium 3 PC: Intel Pentium 3 866MHz, Asus CUSL2-C, 512mb RAM, 3DFX VooDoo 3 2000 AGP
Laptop: Dell Latitude E6430, Intel Core i5-3210M, 6gb DDR3 1600MHz , Intel HD 4000, 250gb Samsung SSD 860 EVO, 1TB WD Blue HDD
Laptop: Latitude 3380, Intel Pentium Gold 4415U 2c/4t @ 2.3GHz, 8GB DDR4, Intel HD 610, 120GB SSD, 13.3" 768p TN, 56Wh battery
Phone: Huawei Honor 9 64GB + 256GB card Watch: Motorola Moto 360 1st Gen.
Laptop 2: ThinkPad T450, Intel Core i7-5600U 2c/4t @ 2.6-3.2GHz, 16GB DDR3 1600MHz, Intel HD 5500, 250GB SSD, 14" 900p TN, 24Wh + 72Wh batteries
Look for the LGA 1366 xeons in the 5500 and 5600 series. They will be much better as @Pasi123 suggested. If you need help choosing there is a whole community that use these xeons
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
Sorry, should have probably stated that, I'm not upgrading, but just building a system, the processes require input like once per 6 minutes most of the time, so my idea was to put the server hardware in my garage or something, and use remote desktop to control it, so yeah, that would include new ram etc, but I don't require any audio output or any other modern features really. I'm just wondering if it's better to use old server than build a budget pc for this task
So if this is a server id just get something like a r710 for this use. Pretty cheap(less than 200 on ebay) and more than fast enough.
Keep in mind that old server boards usually don't have integrated graphics and are often picky on what memory they'll work with.
I'm all for reusing old and used hardware however it might be cheaper and easier just to pick up an old Optiplex or cheap notebook off Craigslist.
