HELP
Go to solution Solved by Flobbster,
Just now, NelizMastr said:
1 minute ago, A Silver said:
As far as I know it is normal for a CPU to hit its max frequency even when not under load.
1 minute ago, Thermosman said:
Yes, thats not a problem
1 minute ago, Konrad Kwasniewski said:
It is fine, mine does same.
Thank you!
Big relief haha.
1 minute ago, Flobbster said:
My cpu is at a very high clock rate at almost no load at all is that normal? and how do i fix it?
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
https://linustechtips.com/topic/893819-help/#findComment-11017505
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
https://linustechtips.com/topic/893819-help/#findComment-11017506
https://www.intel.com/content/www/us/en/architecture-and-technology/turbo-boost/turbo-boost-technology.html
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/893819-help/#findComment-11017508
Thank you!
Big relief haha.
https://linustechtips.com/topic/893819-help/#findComment-11017511
With Intel's turbo boost the max turbo speed is dependant on actual core usage.
For example my i7 6700 does the following:
Base clock speed = 3.4ghz
1 core/ 2threads = 4ghz
2 cores/ 4 threads = 3.9ghz
3 cores/ 6 threads = 3.8ghz
4 cores/ 8 threads = 3.7ghz
I often see windows 10 task manager using 3% CPU but at 3.8 or even 4ghz, but when I render out video using all cores/threads @ 100% I never go over 3.7, ever
https://linustechtips.com/topic/893819-help/#findComment-11017603
