Hello, I have a really simple problem im looking to solve, but am having the darnedest time figuring out. The problem is this: The method 'energy' should evaluate the formula E = mc^2, where the variables 'm' and 'c' are passed in as parameters and E (energy) is the return value.
The solution parameter is listed as :
 def energy(m, c):
    return
Any help would be greatly appreciated!
https://linustechtips.com/topic/893324-python-help/
E = mc 2 definition. An equation derived by the twentieth-century physicist Albert Einstein, in which E represents units of energy, m represents units of mass, and c 2 is the speed of light squared, or multiplied by itself.
I think the part that you are missing is where the speed of light is squared.
https://linustechtips.com/topic/893324-python-help/#findComment-11011793
Not really do to with the coding but why would you pass c as a parameter when c is a constant?
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/893324-python-help/#findComment-11014696
Yeah that'd probably make a lot more sense as a global constant somewhere.
On 04/02/2018 at 6:57 PM, Technicolors said:
you can also do 'from math import pow'
then pow(c, 2)
I usually either import everything ( from math import * ) from a library or just import the library ( import math ) and use math.pow().
Also for the OP, I'd avoid using single letter variable names. While in this case it doesn't really matter since it's a common enough formula that everyone should be able to know what m stands for, it's better to be in the habit to make things human readable. Basically write mass instead of m.
https://linustechtips.com/topic/893324-python-help/#findComment-11020142
c = 299792458
energy = lambda m: m + c*c
print(energy(1))
https://linustechtips.com/topic/893324-python-help/#findComment-11020300
