This is my problem. Whenever i enter any games like (CS:GO, PUBG, Factorio, World of Tanks) The main menu lags. Like lets say i turn up PUBG the fps is very low while launching up the lobby it goes from 20-30 FPS back to the normal 60 FPS and stays there and i can enter the actuall game and it dosent lagg ath all just normal 5-6 FPS drops here and there. And The other problem is whenever i press Stuff like Replays Options Leaderboards or anything in games like that my Main Menu/Lobby FPS goes from a stable 60 FPS to 5-10 FPS it feels like a skiped frame or just really bad lag its duration is like from 1-2 to 5-10 Seconds. Later research i found out that sometimes when i launch up a game GPU usage drops to 0% and CPU and Disk usage spikes up to 100% and goes back to normal after 2-3 Seconds. Once More Gameplay in all of these games seems to be normal. I had a problem with FPS lag spikes while playing actuall games aswell ath random times 5 minutes in or 2-3 hours into the game the FPS would go from a consistant 120 Fps to 20-30 for 5-10 seconds and would go back to normal. The thing i did to fix this was turned on Max pre rendered frames to 4 in Nvidia setttings. And i turned off Scheduled Optimatization in HDD settings that somebody suggested and it fixed the problem.
My PC was built a week ago. Fresh Windows 10 installed. Everything done by a Pro ath a local company. I asked a few questions about Air flow. Components not bottlenecking anything and he sayd everything is going to be fine. And The problem is now if i give it back for repairs/Diagnostics they gona charge it a lot + usually the just say buy this new bla bla .
EDIT: Random Spikes in CPU/GPU and Disk Usage: Whenever launching up games Disk Usage spikes up to 100% and goes back. Disk Usage High Aswell with random Windows programs/background apps. I Found out and monitored sometimes whenever i press something in a game menu lets say in PUBG CPU would do a wierd 100% spike and the GPU usage would go to 0%.
PC Specs : i5 8600k GTX 1060 16 GB DDR4 2400Mhz RAM 1 TB HDD WD blue  [I know i should have a SSD aswell but no money atm] Aours z370 Ultra gaming Mobo 650 W PSU
Idle and Game Temperatures seem to be normal while playing the game.
Things i tryed allready and stuff that usually triggers events like these :
1.)Temperatures are normal for playing games.
2.) GPU,CPU, Disk Usage seem to be normal.
3.) Mobo. , GPU, Windows drivers are up to date
4.) Fresh Install didnt fix it.
5.) After Re-launching the game up again dosent fix it.
6.) Disk usage spikes up when launching up the game and goes back to normal.
7.) Checked HDD health everything was alright.
8.) Installing Old GPU Drivers the problem is still there.
9.) Backwards Installing old Windows 10 update problem is still there.
10.) Disabling Windows Antivirus defender problem is still happening in games
11.) Enabling V-Sync in games dosent fix it or Lowering the Settings to Low/medium.
12.) SuperFetch preFetch Disabled.
13.) Nothing Overclocked.
Searching the net for the last week since i bought the PC and cant find anything. Not in the position to go out and just buy other components. (Was saving up for this PC for 6 Months)
If anybody has any ideas what to do or sugestions what to try pls replay to the topic.
tl;dr --> PC was bulit a few days ago > Everything Freshly installed > Re-Installed all drivers a few times> Main Menus Lag in games FPS goes from 60 to 10-20 fps and when i press stuff like settings leaderboards Lobby duration of it is 5-10 seconds > Temperatures Fine for gaming. CPU GPU Disk Usage Wierd.
Picture 1) Disk Usage While Laucnhing a game
Picture 2) While Leaving a game/exiting
When the game first loads a menu it needs the data from the hdd. No reason to do anything but full speed so thats why it goes to 100. While fetching data from disk it doesn't need to use the gpu because it has no data to send to the gpu yet so it's usage drops. Then it actually loads the menu so it goes to full usage because it wants to do it fast. I don't know why its low fps on menus. It may be that its waiting for data from the hdd but I'm not sure.
If I use words like probably or most likely, it is because I dislike certainty. These words can probably be omitted and the sentence read as a certainty.
I know that but ath Random times Random Windows apps use 100% of my disk usage and the write/read speed seems really slow. Its really annoying and when you launch windows it kinda lags in the begining and while launching games aswell. Gameplay seems to be normal.  I have no idea what to do I see that some people say to change out the HDD and Buy a SSD but there is topics on Google i found where people had the same problem or similiar problems even after chaning out the HDD or SSD. I checked my HDD health on a few programs and they were all fine. And Reinstalled Windows once and the problem was still there. Im loosing my mind over this
One of the reasons win8 and win10 start much faster than win7 is because instead of starting everything and then showing you the desktop it shows you the desktop halfway into starting everything. Also if you are able to play the actual game fine then I would ignore the problematic menus.
Well The Problem is as i stated in the first post. My FPS would lag playing the actuall game aswell the FPS literally goes from 120 ish in games like PUBG and goes to 20-30 FPS for 5-10 seconds and it happends totally random 1 Hour in or few minutes into the game. And i cant see actually what spikes in Task Manager bcs it takes some time to exit the game and i forgot what was the name of that program wich shows CPU cores temperatures GPU and RAM.
I know it seems normal how i wrote you guys but it feels really sluggish it should not be doing this on a brand new PC
Is it a mechanical or SSd drive?
Can you post the make/model of the SSD or HDD it has inside.
and can you check the disk speed, using something like Crystal Disk Mark.
If its mechanical, the slowing down while it loads down the disks and the 100% disk usage is usually normal.
But if its a SSD, those symptoms can be normal, but lets check the disk speeds and see what it says.
Quote
@ElSeniorTaco
WDC WD10EZEXX-75WN4A0  1 TB WD Blue 7200 rpm
This is what it does when i launch up windows.
Its not caused by 1 single program how i see its totally random Windows apps and it keeps hapenin as i sayd when i launch up games aswell.
1 Picture While Launching up Windows
2 Picture While Testing in Crystal Mark
3 Picture End of Testing in Crystal Mark
