4 minutes ago, danted16 said:
so it is failing?
you betcha its failing!
20 minutes ago, danted16 said:
I recently bought a wd blue 2tb 5400 rpm drive. It is making very loud scratching noises. Is this normal? listen to audio file. https://drive.google.com/file/d/1DWRoBtDKm8fhfqXL_QnwoiUfrxIjzRC4/view?usp=sharing
return the hdd to where you purchased it from
Noise coming from the hard drive, is not good.
How close to the hard drive were you when that was recorded? I have the exact same drive and that's how it normally sounds when the head is moving, although mine sounds slightly deeper.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
