Hi,
I have recently built a cheap pc and it was working. Here are the specs:
Dell precision T5400:
Dual Xeon E5420
PNY Nvidia Geforce GTX 570 enthusiast edition 1280mb
32GB ECC FB-DIMM DDR2 RAM
500 GB HDD
The PSU is rated for up to 875 watts and it is an oem dell psu with 80 plus certified and has two 6 pin power connector for the gpu
And my monitor uses DVI
But later on I noticed a problem where after putting the pc to sleep it would not give a signal once I moved the mouse or clicked the keyboard. I would have to shut it down and restart it, and sometimes even that wouldn't work and sometimes it did. Now it doesn't give any signal at all. So I thought either it was a gpu problem or the motherboard/cpu/RAM problem. So I took my gtx 570 and placed it into another pc and it booted up properly and then I put a gt 210 into the Dell and it worked too. So that means everything is working right? I put the GTX 570 back in the Dell and it doesn't boot up.  I even reset the CMOS battery but it still doesn't give a signal. All the fans are spinning. I even checked a psu calculator to see if it wasn't the problem, and I have 200+watts headroom so I think it is good.
I really don't know what to do, and any help would be really appreciated.
https://linustechtips.com/topic/891137-gpu-not-giving-signal/
26 minutes ago, Ojus said:
Hi,
Dual Xeon E5420
500 GB HDD
Make sure you only have as many pcie devices as your mobo can support. If you have more it might shut off the gpu.
Case: InWin 303 Motherboard: Asus TUF X570-Plus Processor: Ryzen R9-3900x GPU: Gigabyte RTX 3070 Ram: 32 GB DDR4 3000 MHZ
 PSU: Corsair CX750M Storage: 1TB Intel 660p NVME SSD and a 2TB Seagate 7200RPM HDD Mouse: Logitech G600 Keyboard: Razer Blackwidow Ultimate 2014 HeadphonesSteelseries Arctis 7 Audio: Shure PGA58 with a Focusrite Scarlett Solo 3rd Gen
https://linustechtips.com/topic/891137-gpu-not-giving-signal/#findComment-10989525
I know this might sound stupidly simple, but you're not using the wrong TV channel are you? If you have a monitor, though, that's a moot point.
Is your DVI fully shoved in to it's socket?
Maybe update monitor driver via Device Manager?
I don't know, mate. Tis an odd problem for sure.
EDIT: Also, again a simple suggestion, I know, but are you shoving the 570 fully into the PCI slot?
https://linustechtips.com/topic/891137-gpu-not-giving-signal/#findComment-10989527
I don't know how to change channels on a monitor, also yes it is pushed in properly. Also how would you update monitor drivers if the PC won't give signal to the monitor and the dvi is fully pushed in.
But Thank you for the response
https://linustechtips.com/topic/891137-gpu-not-giving-signal/#findComment-10989665
The motherboard has two PCI-E 16x
 slots and and one PCI-E 8x slot it also has two PCI-X and one PCI slot. I am not sure which version of PCI-E Slot it is though (whether 1.0, 2.0 or 3.0) I am only using one PCI-E 16x slot, which is used by the GTX 570.
https://linustechtips.com/topic/891137-gpu-not-giving-signal/#findComment-10989698
1 minute ago, CDHoward said:
Is there no way you can use HDMI or display port?
Do you have a DVI to HDMI adapter by any small chance?
I tried on my TV and it has HDMI and the same thing happened the fans start and I here a beep indicating windows starting up but I don't get any signal. The computer was working before So I am not sure what is going on.
Thanks again
https://linustechtips.com/topic/891137-gpu-not-giving-signal/#findComment-10989712
34 minutes ago, Tosa said:
If it has integrated graphics, you should check if that outputs video, with and without the dedicated graphics card.
Sorry, that isn't possible as the xeons I have don't have integrated graphics.
Thank you for the response!
https://linustechtips.com/topic/891137-gpu-not-giving-signal/#findComment-10989934
So does anyone else have any other solutions, a friend of mine suggested maybe it was the two 6 pin pcie power connectors on the Dell not giving power. But it was working a week back and the fans do spin. Do you think this makes sense and this might be the problem?
Please any help would be appreciated!
Edited by Ojus
Forgot to add something
https://linustechtips.com/topic/891137-gpu-not-giving-signal/#findComment-10990550
