Two different GPUs in system - massive slowdowns
I am using two different GPUs in my system, one for general use, and the other for mining only. However, just recently the performance of everything has degraded horribly. I cannot even watch a video on the computer unless I remove the second card. I have read online that there shouldn't be a problem, but there is. Any ideas?
Note: the cards are a 1070 and a 950 I had laying around.
Don't forget to "Quote" when replying so we can see it.
Just now, emosun said:
what psu
what temps
what voltages
EVGA 650 watt GQ
950 stays around 50 degrees, 1070 can reach around 70-75 when gaming
Stock voltages
3 minutes ago, Dragonheart said:
950: 1212 mv
1070: 1012 mv
this helps?
no I mean stick a multimeter on the power lead on the psu and see what it's actually making under load.
while the psu SHOULD be enough it's best to check that it's actually working properly. if the machine works fine with only one gpu rather than two a power problem could be to blame.
Are these slowdowns happen while you're trying to use the machine and mine at the same time?
The problem persists even when both of the GPUs are at idle.
You could also uninstall your display drivers and then reinstall them. They may have issues id they are trying to run on different drivers
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
1 minute ago, emosun said:
you can try a system restore then to a point when it was working to see if it's software related.
I already reinstalled first the driver and then Windows. I can try again I guess.
Will try (again), thanks.
