So my pc was on in all and right as the screen turned black I moved my mouse to turn it back on and after that the monitor keeps saying display port no signal... I’ve tried using hdmi cable and it says hdmi no signal so what did I do? Also the monitor has the orange light once it says no signal
https://linustechtips.com/topic/890283-help/
SOunds like something could be wrong with the cable. The monitor when it has the orange light come on is simply going to sleep because it's not getting any kind of signal. Once you get a working cable that put the signal through it should turn back on and flick green.
https://linustechtips.com/topic/890283-help/#findComment-10980936
