Hey guys i want make a smaller PC. I stopped gaming a while back and could use some help with setting up a new build. I currently have a gtx 970 but the rest of the build I would like new. I move a lot and need something i can bring around easily. I play alot of Arma 3 so a solid processor is nice and really just want to game at 1080p on max for any game. or best i can do with a 970.
Steam:Drift and Drift_2 <p>(name is hunter) Lets play:)
https://linustechtips.com/topic/889977-building-a-smaller-build/
Just now, SCGazelle said:
you mean <$900 right? Also how small do you want it? like Mini ITX or a small mATX?
hahaha yea <900. Yea mini ITX is fine as long as you think it will be cool enough. with whatever cooling you reccomend
1 minute ago, openthatchest said:
i'd say these are all the height of your elbow->fingers if not less
would I be able to fit my Nvidia 970 in the last two? they look to have smaller graphics cards.
I haven't been up to date much with the newer hardware but this looks good to me. You'll be bottlenecked by your GTX 970 so upgrade that too if you need more performance. Also I'd wait for someone to give thier opinion on this build before you use it:
PCPartPicker part list: https://pcpartpicker.com/list/W3NsHN
Price breakdown by merchant: https://pcpartpicker.com/list/W3NsHN/by_merchant/
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($378.89 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.89 @ OutletPC)
Motherboard: MSI - Z370I GAMING PRO CARBON AC Mini ITX LGA1151 Motherboard  ($142.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($169.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($46.55 @ OutletPC)
Video Card: NVIDIA - GeForce GTX 970 4GB Video Card  (Purchased For $0.00)
Case: Fractal Design - Define Nano S Mini ITX Desktop Case  ($59.99 @ SuperBiiz)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Amazon)
Total: $893.28
Generated by PCPartPicker 2018-01-26 00:10 EST-0500
6 minutes ago, docterkiwi said:
I have Windows on an SSD 250gb. I dont trust my old 1tb Hard drive though.
Make sure you run sysprep before transferring your drive(s).
thanks. I'm also looking at doing AMD to save money.
Here ya go, 1600 is the sweet spot for gaming.  Use this mod to get best thermals and throw 2 120mm fans in the gpu section.
PCPartPicker part list: https://pcpartpicker.com/list/M49nm8
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($187.39 @ SuperBiiz)
CPU Cooler: CRYORIG - C7 40.5 CFM CPU Cooler  ($29.99 @ Amazon)
Motherboard: ASRock - X370 Gaming-ITX/ac Mini ITX AM4 Motherboard  ($129.99 @ Newegg)
Memory: G.Skill - Aegis 16GB (1 x 16GB) DDR4-2400 Memory  ($164.99 @ Newegg)
Case: Fractal Design - Node 202 HTPC Case  ($69.99 @ Newegg)
Power Supply: Corsair - SF 600W 80+ Gold Certified Fully-Modular SFX Power Supply  ($115.78 @ Amazon)
Total: $698.13
Want to custom loop?  Ask me more if you are curious
i7-8700 performance is very close to the i7-8700K at stock. It is a 65W TDP cpu, so it runs much cooler and will be fine with its stock cooler.
A single stick of memory to leave the second slot open for an upgrade.
Case has a handle for convenient transportation.
CPU: Intel - Core i7-8700 3.2GHz 6-Core Processor  ($359.00 @ B&H)
Motherboard: ASRock - Z370M-ITX/ac Mini ITX LGA1151 Motherboard  ($131.89 @ OutletPC)
Memory: Kingston - FURY 16GB (1 x 16GB) DDR4-2666 Memory  ($178.99 @ SuperBiiz)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  (Purchased For $0.00)
Storage: Seagate - BarraCuda 1TB 2.5" 5400RPM Internal Hard Drive  ($49.56 @ OutletPC)
Video Card: EVGA - GeForce GTX 970 4GB SSC ACX 2.0+ Video Card  (Purchased For $0.00)
Case: Silverstone - ML08B-H HTPC Case  ($70.04 @ Amazon)
Power Supply: Corsair - SF 450W 80+ Gold Certified Fully-Modular SFX Power Supply  ($89.34 @ Newegg)
Total: $878.82
Generated by PCPartPicker 2018-01-26 00:43 EST-0500
Or you could get an 8700k for a tiny price bump and undervolt it for an effective 65w cpu
One could, but I'm not sure it's worth the effort. Besides, one would then have to add the cost of a low profile cooler like the C7 or NH-L9i.
The 8700k holds its value better and can be overclocked with a delid, worth it considering the small 20 + 30 bump in price
