Newly built PC - Shutting down after some hours of heavy load
@Doomed83 Thought I'd give you an update! It seems like the problem has been fixed. I went to check so that all my cables were plugged in correctly - which they all seemed to do. However, my 24-pin was a little loose. I'm not sure if I made it loose as I was checking or if it already was. But because of this I decided to unplug my PSU completely and then plug it back in whilst making sure every single cable was plugged in correctly. Since then I haven't had any shutdowns. I've had sessions where I've played 6+ hours straight and I also ran a stresstest while I was sleeping which lasted 8 hours before I turned it off manually.
I still dont don't trust the PC completely. But for now I'm going to assume that the problem has been solved. Thanks a lot for your help and to all of the others as well!
