Alright, so I have some code which converts "raw data" from my serial port to a proper format. Here is what I mean:
This line
b'\xdb0\xc30\xc30\xc3\x98\x98\x00\x00mm'
Gets changed into this
db 30 c3 30 c3 30 c3 98 98 00 00 6d 6d
Here is the big issue though. I need to be able to grab the last digit from that string (6d) and turn that into a variable so I can do stuff with it. I can't figure out how to do this with no matter what research I do.
Any help would be appreciated.
Current Code:
import serial
import time
port = serial.Serial("/dev/ttyS0",
                     baudrate=9600
while True:
    raw_output = port.read(13)
    for a in raw_output:
        print(format(a, "02x"), end=" ")
    print()
Tech enthusiast and CS Student
https://linustechtips.com/topic/889577-python-help-parsing/
