Help with ram purchase
Solved by Princess Luna,
In my point of view you should go with the single channel since latency will be smaller which helps out with Infinity Fabric, gaming performance wise the difference between single and dual channel is within 2~3fps compared clock for clock, which is negligible to some degree, but then we weight the fact Ryzen craves frequencies and this 2666mhz module has better chances of working at 2933 or higher which would wield more performance increase.
The single stick solution usually is superior price wise which is appealing right now with the ludicrous pricings, furthermore you get way more room for upgradability, if you ever need a workstation simple throw another 1x16gb and a Ryzen+ 7 refresh and there you go.
Cheers.
