Recording with OBS
Solved by STRMfrmXMN,
7 minutes ago, DC said:I5 6500
16gb ddr4
Gtx 10606gb
You'd want a much more powerful CPU for CFR. My 1700X seems to do alright with ridiculous OBS settings. When I had an i7 4770, I generally avoided using X264. Your CPU is worse than my old i7, so use the lightest settings in OBS that you can.
Can you screenshot your important settings? Can you also try using NVENC or Quick Sync? Quick Sync requires some set up but it's awesome if you can get it working.
