Help with onboard Audio
DrBonesMcCoy
I am currently using a G35 (USB headset) but my motherboard, a Maximus X Hero (z370) has a built in dac and amp I believe. Is it possible an audio jack to usb adapter would see an improvement in sound or am I better going with a Sennheiser game zero headset which uses audio jacks? Thanks
The Darkened Phantom(With some light shining through)
CPU: I7-8700K @4.9Ghz 1.313 V Core
COOLER: Corsair H115i
GPU: 1070 Founders Edition @Stock settings
RAM: 16GB DDR4 CL14 TEAM GROUP DARK PRO 8PACK Hand picked Samsung B-Dies @ 3200mhz
PSU: Corsair RM 850X
CASE: Enthoo Pro M Special Edition
STORAGE: 1X 128GB SSD, 1X120GB SSD, 1 X 500GB NVME PCIE SSD and 1X 2TB HDD
To add, headset recommendations are appreciated. Preferably closed back with a mic and stereo as I play games like PUBG and R6S.
As for your first question: no, the G35 has an inbuilt "soundcard" and acts like one. The USB is just the data interface and wont accept an analog signal :D
Ok. Would I be better off getting a GAME ZERO? When using the mic on my G35 there is an annoying high pitched noise. Would I see better sound with another headset like the one I mentioned?
