I'm actually done with Ryzen right now, I have tried every single possibility of trouble shooting and I cannot find what the reason for this stuttering is. Every time I THINK I have a solution, it ends up giving me false hope.
List of things I've done:
1. Rebuild computer.
2. Re-install windows.
3. Re-install windows on different boot devices.
4. Buying a new mother board, (This actually reduced stuttering slightly.)
5. Updated AM4 chipset drivers.
6. Updated BIOS.
7. Used Prime 95. (Roughly 2 to 3 hours)
8. Took out one stick of Ram to test each stick and slot individually.
I'm going to Intel. This is not worth my time.
Watch that for video vvvvvvv
https://youtu.be/zz8AMUTVoNs
https://linustechtips.com/topic/888266-ryzenperformance/
No information given on what your system specs are........
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960503
Which Ryzen are you using?
What is your full spec sheet -  Ram type, speed, manufacturer?  GPU?  HDD/SSD's?  Gaming Peripherals (USB headsets / DACs)? Is your copy of windows legit or cracked?
Does this stuttering occur when you are not recording / streaming?  What recording/streaming software are you using?
I'd laugh my rear end off if you purchased a new Intel CPU and mainboard just to find you had the same issue because you didn't look at other attached devices as a potential vector for your issues.
Main Rig:
Case: Lian Li Lancool Mesh RGB
CPU: Ryzen 5 3600
Cooler: CoolerMaster MasterLiquid 240
MB: MSI B550 Gaming Pro Carbon
Ram: Gskill DDR4 3600 x 32GB
GPU: Asus Arez Strix Vega 64 OC
PS: Seasonic FOCUS Gold Plus Series SSR-750FX
SSD1: Crucial P1 1TB NVME
SSD2: Adata SU800 512gb M.2 Sata
HDD: Hitatchi 2tb 7200RPM + 3x 2TB WD Passport USB 3.0
Monitors: AOC C24G1
Keyboard: Cheap Blue Knockoff Mechanical
Mouse: Uhuru Gaming Mouse
OS: Pop! 21.04
Current Vintage Equipment:  Please ask me about it, I love to talk old tech!
IBM Thinkpad 390, IBM Aptiva A12, IBM PS/2 Model 25-004.  Compaq Contura 4/25C, Presario 7596
Asus P5A-B Socket 7 Box, Tandy 1000RLX-HD "B" & 1200-2FD, VIC20, Zenith ZFL-181-93, Packard Bell 300SX.
Apple II/gs, Mac Plus x2, Mac SE x2, Performa 450
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960506
1 minute ago, ViolentBoo said:
My apoligies, I copy pasted from a document and I didn't select everything aparently.
Ryzen 5 1600
Gigabyte AB350M D3H
16GB Crucial DDR4 RAM 2133Mhz, OCd to 2666
Evga 450 Watt PSU
256Gb SSD by WesternDigital Blue,
1TB Caviar Black
500GB Segate
According to this your PC should not even be usable.
You dont have a GPU!
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960518
Ryzen 5 1600
Gigabyte AB350M D3H
Evga 450 Watt PSU
1TB Caviar Black
500GB Segate
What Graphics Card?  Do you use any USB Audio Devices (Headset / DAC)?
Main Rig:
CPU: Ryzen 5 3600
Monitors: AOC C24G1
OS: Pop! 21.04
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960524
Windows is genuine, Corsair Strafe RGB (I don't have the Corsair utility installed, I've heard it hindered performance so I stayed away. Also i was using a differnt keyboard before and it was doing the same thing. Hyper X Revolver.
The stuttering occurs Mainly in league its most noticeable. Osu will freeze rarely on song selection but not in gameplay (thank god) main games I play typically.
UGH sorry I can't type, GTX 1070 Zotac AMP! addition, 8GB
I don't use an USB audio device, just ones that plug into the back of the comptuer green and pink holes.
Also with the graphics card, I've used it in another computer, because I ordered this part long before I decided to buy all the new parts.
Also a thing i forgot to mention is that sometimes videos on YT will also stutter. It's not common but it still happens. Liek just now I watched a linus video of a corsair logo zooming in and it skipped a few frames.
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960525
Have you tried with your RAM not overclocked?  Is your CPU overclocked (manual or auto)?  Is the EXACT RAM model number listed in the QVL memory list for the motherboard?
I'd bet on an Overclock or RAM incompatiility issue first.  Next, I'd look at the SSD (try running health check in Crystal Disk Info).
Main Rig:
CPU: Ryzen 5 3600
Monitors: AOC C24G1
OS: Pop! 21.04
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960541
I'd bet on an Overclock issue first.  Next, I'd look at the SSD (try running health check in Crystal Disk Info).
I've only OC'd the RAM about a month ago and it's been stuttering ever since I built it, I thought that would fix the problem but it didn't and I didn't bother changing it back.
I've bought this ram, https://www.amazon.com/gp/product/B00MMLUYQK/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
As for the health of the drives they're all fine except for the 500Gb HDD, although I don't really care much for that drive it's almost 9 years old or so.
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960557
What is the issue with the 500gb drive?
Is Windows managing your virtual memory automatically?  If so, It may be a fault with Windows trying to use a paging file on that drive.  Have you tried running the games with that drive disconnected?
Main Rig:
CPU: Ryzen 5 3600
Monitors: AOC C24G1
OS: Pop! 21.04
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960565
4 minutes ago, ViolentBoo said:
That RAM is not listed on the Memory Support List for your motherboard.  I'm not saying that's a guaranteed issue, but it could be a contributing factor.
http://download.gigabyte.us/FileList/Memory/mb_memory_ga-ab350m-d3h.pdf
Main Rig:
CPU: Ryzen 5 3600
Monitors: AOC C24G1
OS: Pop! 21.04
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960570
Wait there is RAM that just doesn't work completely with Ryzen????
That is blowing my mind. I have a repuatible computer repair shop near me, I'll go there and see if they have any of those ram selections. I'll keep you posted about it.
As for the drive,
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960593
GTX 1070
27 minutes ago, ViolentBoo said:
Evga 450 Watt PSU
gee.... if only we could figure out the problem guys.....
whatever you do , don't check it with a multimeter or anything. just say it'll work or it should work based on an online power supply calculator. lol
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960597
RAM compatibility is up to the motherboard manufacturer.  They put out a list like I posted above for every motherboard.  This is RAM that was tested with the board and guaranteed to not cause issues.  It is not a Ryzen specific thing.  Intel boards all have RAM compatibility lists as well.
Ryzen does seem to be more picky about non QVL'd ram than Intel, but you should always use the QVL when purchasing parts :)
Main Rig:
CPU: Ryzen 5 3600
Monitors: AOC C24G1
OS: Pop! 21.04
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960600
THANK YOU, so much right now, I'll get new Ram soon i'll keep you all posted!
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960606
I would seriously check out that 500gb drive as well.
Main Rig:
CPU: Ryzen 5 3600
Monitors: AOC C24G1
OS: Pop! 21.04
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960608
PSU isn't the problem.
ah don't worry guys the 20$ power supply isn't the problem
glad that's solved. here i was thinking you bought the cheapest power supply possible and didn't actually check it's output voltage and amperage at all.
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960611
2 minutes ago, ViolentBoo said:
There's nothing really important on that drive. Unless if you think it's making the stuttering issues. If it dies, it won't really be an inconvenience.
Windows allocates virtual memory (Swap Files) on pretty much all drives by default.
If it's loading background processes onto a failing drive's Swapfile, it can definitely cause issues.
It's easy enough to test, just unplug the drive and see if performance improves.
Main Rig:
CPU: Ryzen 5 3600
Monitors: AOC C24G1
OS: Pop! 21.04
https://linustechtips.com/topic/888266-ryzenperformance/#findComment-10960622
