MONITOR DISPLAY
WOLVERINE007
HEY GUYS RECENTLY BOUGHT A LG 22MP68VQ-P  MONITOR . BUT GETTING PIXELETED AND HAZY GRAPHICS. I AM USING A ASUS ROG STRIX GTX 1060 6GB AND WITH ALL DRIVER INSTALLED. PLEASE HELP GUYS!!!!
Might be something in the nvidia control panel going wrong, do you have a second monitor?
hi
yes bro
4 minutes ago, Crunchy Dragon said:
Go into your Display Settings in Control Panel and turn up the resolution.
its already maximum
what IO are you using?
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 9 3900X|  |Cooling: Enermax Liquimax III, 6x 120mm Noctua Redux|  |Motherboard:  MSI MPG B550 Gaming Plus|  |RAM: 4x32gb 3200 G.Skill TridentZ NEO|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: Corsair CX-M 750W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb WD BLACK NVMe, 500gb NVMe, 1Tb Samsung 850 EVO|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G203 LIGHTSYNC|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
2 minutes ago, WOLVERINE007 said:
yes bro
Whats the resolution of your other monitor?
hi
its a 720p monitor, after disconnecting it also the same issue is there
couldnt get you??
Just now, WOLVERINE007 said:
couldnt get you??
VGA, HDMI, DP, DVI?????????
My Stuff n' Things
6 minutes ago, WOLVERINE007 said:
its already maximum
scaling in windows ?
1 minute ago, WOLVERINE007 said:
what?
windows has scaling options for resolutions, it can make things hazy and pixelated.
hdmi
I asked because VGA is not well known for good picture
My Stuff n' Things
how to fix that?please help
go into the windows display settings,
(windows key, gear, system)
set it to the recommended value, still the problem is there!!!
did you restart your pc after you installed the drivers ?
yes bro several times!!!
try installing this one
http://www.lg.com/hk_en/support/support-product/lg-22MP68VQ-P#
maybe contact LG about it ?
they should be able to help you out with the monitor's settings (and I have to go for the next like 6h so I can't help you any more for now.
hope it helps.
