I just finished my build, and I wanted to overclock my cpu to get the most performance out of it I’m unsure on how I should overclock I went into the bios and didn’t know what to do from there
DEEPCOOL Captain 120EX Gamer Storm 120mm - CPU Cooler AIO
i7 8700k - CPU
MSI Z370 GAMING PLUS - motherboard
https://linustechtips.com/topic/887589-help-overclocking-cpu/
I suggest u to go on youtube and serach for i7 8700k overclocking Tutorial. Almost all Bioses are very similar.
|| CPU: I7 6950X @4.6 (1.35V) || Cooler: CUSTOM EK LOOP || Motherboard: ASUS RAMPAGE V EDITION 10
|| GPU: 2x Vega 64 Strix OC @1762 / 1100 MHz || Memory: 16GB G.Skill Royal RGB 3200 Mhz ||
HDD: Segate Barracuda 3TB || SSD: Samsung 970 Evo 512 GB || PSU: Corsair HX 1200 W || Case: Fractal Design Define R6 Gunmetal || Fans: Corsair HD120 (x4) / BeQuiet Silent Wings 3 (x4) || Monitor: ACER XF27HU ||
Second Monitor: BENQ RL2455HM || Mouse: Logitech G502 Pretus Core || Keyboard: Logitech G810 Orion Spectrum || Headphones: Sennheiser IE80 ||
        Buildlog expirience swapping to x99:
https://linustechtips.com/topic/887589-help-overclocking-cpu/#findComment-10953930
You don't want to overclock a 8700k with a 120mm AIO. You cannot dissipate enough heat.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/887589-help-overclocking-cpu/#findComment-10953958
I wouldn't OC on that cooler (at least not much higher), since the 8700k is an incredibly hot and power hungry monster. However, OCing is very simple once you learn how. I highly suggest watching a tutorial.
Otherwise..
1. Disable any sort of power saving features
2. Learn what default voltage is, and set it to that manually (never touched an 8700k, not sure).
3. Set the clock to it's default default clock (maybe 4.2-4.5ghz)
4. Stress test for 30 minutes. If passed, increase the clock 100mhz at a time. If it crashes, increase voltage by one step (if at 1.24v, try 1.25v), and repeat the stress test.
Basically go until you either can't push it any further, or until the temp hits an extreme. I would turn down the clock and voltage if it hit 80c during a stress test. A stress test is pretty unrealistic, and while gaming, your PC will not hit those temps, but it's a good reference for 'worst case scenario'.
ALSO, lower end motherboards will lose voltage while under load, this is known as vdroop. If you're crashing, this could be why, NOT because you need more voltage. If you set the vcore (example) to 1.3v, but once you stress test, you see it dip to 1.26, that might be too much vdroop to maintain that clock. The setting to counter this, is called LLC (load line calibration). Be careful with this, because it forces more voltage to counter it.
This is just a quick run down. I advise looking into HOW this works, and WHY before tampering with these settings.
Good luck :)
Ryzen 7 2700x, MSI Gaming X RX 480 8gb, Asus ROG X470 Gaming, 2x8gb Corsair Vengeance LPX 3000, 120gb Kingston SSD (Boot) + 1TB Seagate Barracuda.
https://linustechtips.com/topic/887589-help-overclocking-cpu/#findComment-10954097
First you should run AIDA64 or prime95 stress test to see what are your temps under load.
For aida64, select CPU+FPU+Cache stress test and report back your results.
If you have enough headroom for overclocking, just change voltage to something like 1,325 and frequency 4,8GHz.
Then check again your temps.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/887589-help-overclocking-cpu/#findComment-10954284
