Hey guys.
So for the last week or so i've been having this weird stuttering within CS:GO(only CS:GO, other games i've tried have been fine) my FPS is 300+(even limited to 75 with freesync on, the stutter is still there) and neither CPU or GPU are hitting 100% load. RAM isn't an issue as i have 16gb's, and only about 3-4 total is being used.
Internet shouldn't be the issue either, when in games my ping is between 40-60 and my connection is about 50Mbps down, 12Mbps up.
I've tried literally every fix from google, apart from re-installing windows which i'm not gonna do, just wondering if anyone else has a "fix" that may work.
What i've tried -
Disabled Xbox DVR
Set shader cache in radeon settings to "on", this was apparantly a fix that I found on reddit
Re-installing CS:GO
Changing the CSGO.exe file compatibility mode, and disabled/re-enabled full screen optimisations
Most up-to-date amd drivers.
Most up-to-date audio drivers(some random youtube video "fix")
Here's a little clip to show the stuttering, as you can see, i'll start shooting at someone who's in my crosshairs and then they jump out of them, or when im walking i'll randomly "rubber band" a step or two back.
https://linustechtips.com/topic/887286-csgo-stuttering-issues/
Open net graph (net_graph 1) and check whether you have var or sv spikes. Also, are they any background processes running while in game?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/887286-csgo-stuttering-issues/#findComment-10950919
var is between 0.1 and 4-5ms but doesn't jump around much, sv is jumping around quite fast between 4-8, went up to 11 highest.
https://linustechtips.com/topic/887286-csgo-stuttering-issues/#findComment-10950927
this may be the best way unfortunately
Does it only happen while playing with human? Try playing with bots and see whether the problem is still there. Looks like there's some kind of internet connection problem IMO (I just watched the video, no data here)
Desktop specs:
https://linustechtips.com/topic/887286-csgo-stuttering-issues/#findComment-10950945
Didn't think to test it offline, offline with bots i get no stuttering... so something with my connection is going funky. I've already tried to renew my ip through cmd, and the lan drivers are up to date.
https://linustechtips.com/topic/887286-csgo-stuttering-issues/#findComment-10950961
Does this happen at all resolutions?
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/887286-csgo-stuttering-issues/#findComment-10950966
I only ever play at 1080p, but up until a week or so ago it was fine at this res.
Try chaning it to something like 1024, 4:3.
https://linustechtips.com/topic/887286-csgo-stuttering-issues/#findComment-10950973
