i got this hard drive out of a laptop and installed it in my computer, and i noticed in disk management that there were 4 recovery partitions tied to it that i cant get rid of. Is there anyway that i can remove them or shrink them so they use a tiny amount of space. (picture included)
EDIT: problem solved
https://linustechtips.com/topic/887268-drive-management-problems/
You can either format the entire drive, or if you wish to keep the data on it, you can boot into a live Linux Distro and resize the partitions there. However, personally I find it less time consuming to just copy the data you want to keep off the drive, format it, then copy stuff back to it.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
I had already formatted the drive before i noticed the 4 partitions. is there any way i can do it in windows?
Yes, you can use diskpart via the command line to format the drive. There are guides below for doing this.
Be careful as you can nuke the wrong drive if you're not looking.
http://knowledge.seagate.com/articles/en_US/FAQ/005929en?language=en-ca
https://www.sevenforums.com/tutorials/52129-disk-clean-clean-all-diskpart-command.html
5 minutes ago, kirashi said:
Yes, you can use diskpart via the command line to format the drive. There are guides below for doing this. Be careful as you can nuke the wrong drive if you're not looking.
thankyou that looks like it has worked
By the way, you need the EFI system partition, so never delete that or Windows won't boot, ever again.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
1 minute ago, _exp_ said:
the drive i was talking about i had extracted out of my old laptop and doesnt contain my boot files for my desktop
Aight :)
