So I have a drawer unit next to a plug socket and on one of the plugs is a oneplus brick. But when the draw comes out it hits the brick.
So what I am asking is there anything that lets me plug it into the socket and then plug the oneplus brick from the top instead of normally.
Thanks!
Specs:
Motherboard: Gigabyte Z97X Gaming 3
CPU: Intel Core I7 4790K
GPU: Gigabyte G1 Gaming GTX 970
RAM: HyperX Fury 16GB
HDD: Seagate ST3000DM001 3TB
SSD: KINGSTON SV300S37A480G 450GB
Cooler: Corsair H100i GTX
Case: NZXT H440 Red
Monitor: DELL U2412M
Keyboard: Gigabyte Force K7
Mouse: Corsair Sabre RGB
https://linustechtips.com/topic/885534-socket-help/
Thanks!
This would be the simplest, there are USB plugs that plug in from the sides instead of directly in front.
https://www.amazon.com/Cable-Matters-2-Pack-3-Outlet-Grounded/dp/B01LY5WXBY/ref=sr_1_3?ie=UTF8&qid=1515872872&sr=8-3
https://www.amazon.com/Belkin-3-Outlet-SurgePlus-Protector-BST300/dp/B00ATZJ5YS/ref=sr_1_15?s=electronics&ie=UTF8&qid=1515872964&sr=1-15
https://linustechtips.com/topic/885534-socket-help/#findComment-10934250
Is there any British version of them adapters?
Specs:
Case: NZXT H440 Red
https://linustechtips.com/topic/885534-socket-help/#findComment-10934739
Yes but it's much more bulky, at that point it would be easier to just get a new USB adapter if you looking for space savings.
https://www.amazon.co.uk/Eagle-2-Way-Socket-Splitter-Adaptor-white/dp/B000L1MUME/ref=pd_bxgy_147_img_3?_encoding=UTF8&psc=1&refRID=FK4JVWP0D9VFC5D3STMK
https://www.amazon.co.uk/Amazon-PowerFast-Original-Charger-eReaders/dp/B01I0IGFZM/ref=sr_1_23?ie=UTF8&qid=1515881540&sr=8-23&keywords=usb+power
https://linustechtips.com/topic/885534-socket-help/#findComment-10934748
I have plenty of the block adapters, but what I mean is are there any British adapters when I can plug one into the top just like that American one?
Specs:
Case: NZXT H440 Red
https://linustechtips.com/topic/885534-socket-help/#findComment-10937378
Not really other than that cube adapter, the Type G plugs are much larger so you won't have a slim option like those ones.
https://linustechtips.com/topic/885534-socket-help/#findComment-10937582
Okay then thanks. Big help!
Specs:
Case: NZXT H440 Red
https://linustechtips.com/topic/885534-socket-help/#findComment-10937783
