hey guys, I'm planning to build an i5-8400 based pc and currently waiting for the h and b series motherboard. If I use a gtx 1070 in the build, will the i5 cause a bottleneck? If no then I'll probably run the stock cooler for a few months to squeeze in the 1070. Thanks in advance people! ?
https://linustechtips.com/topic/885514-will-it-bottleneck/
No, it's going to be fine with a 1070.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/885514-will-it-bottleneck/#findComment-10933978
No and just use the stock cooler. Theres no difference whatsoever in performance unless its throttling (which it wont unless something is wrong.)
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
https://linustechtips.com/topic/885514-will-it-bottleneck/#findComment-10933997
