Ryzen core temps
Go to solution Solved by Zagna,
Only package temp is available since SenseMI uses almost 1000 sensors throughout the chip for monitoring and only gives out a single reading from that.
Hey,
Is there any program that can tell Ryzen core temperatures? I tried every program I know but all only show package temps.
Thanks in advance.
My Box of Fµn:
CPU - AMD Ryzen 5 1600
GPU - Gigabyte GeForce GTX 1080 Windforce
RAM - Corsair Vengeance LPX 16GB DDR4
MoBo - MSI B350 PC Mate
Case - Phanteks P400s Tempered Glass
PSU - BeQuiet 500W PurePower 10
Fans - BeQuiet PureWings 120mm x3; 140mm x2
Cooler - Corsair H100i v2
and THE POWER OF RGB
https://linustechtips.com/topic/885456-ryzen-core-temps/
Alright. Is it possible to read out the other values somehow?
My Box of Fµn:
https://linustechtips.com/topic/885456-ryzen-core-temps/#findComment-10933495
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
https://linustechtips.com/topic/885456-ryzen-core-temps/#findComment-10933497
