Corsair ML120 RGB fans and Corsair Commander Pro
EroticToast
I'm new to the whole Corsair scene so maybe this is a dumb question.. and hopefully someone familiar with these products can help.
I have 2 RGB ML120 fans in my system and I just added a Commander Pro. It was my understanding that the Commander Pro could control both the fan speed and the RGB lighting of the ML120 fans.
However, the fans have two leads coming off of them, 1 is a 4 pin for PWM, the other is a 4 pin female (presumably for RGB). The Commander Pro has male connectors for "LED", but these are 3 pin and won't connect to the mystery 4 pin leads on the fans.
The Commander Pro seems to be controlling fan speed in Corsair Link software correctly, but doesn't seem like it's able to control RGB with the current connections that I have established. Am I just really stupid? or does the $70 Corsair box that I got not enable me to control the lighting on my Corsair fans?
Thanks for your help,
Jacob
12 minutes ago, EroticToast said:
-SNIP-
The RGB system on the fans connect to the RGB hub which then interfaces with the Commander Pro unit. You must have the hub for the RGB on the fans to function.
Related image
