My maximum screen resolution has increased
Solved by geo3,
1280 x 1024 is the highest that will ever display because that's the number of pixels physically on the screen. Something messed with the your video settings and made it output a higher resolution which was then interpolated down to your monitors native res. Interpolation is why it was blurry. If you want higher resolution you need to buy a new monitor.
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
18
