2 minutes ago, Merrymaan said:
What do you mean by not being perfect? Is the audio stuttery or crappy? Will this mobo be a downgrade from an xbox audio lol?
no audio stuttery or crappy audio on my board. what i meant was: if it was not absolutely perfect i wouldn't notice because i'm not looking for it. I know the audio is not crappy or stuttery because i would have noticed that even whem I'm not listening for it. I played a decent amount of PUBG ont my rig with the AKG K553 pro headphones and i could perfectly hear footsteps outside houses and i could position the footsteps lik on any other PC i've used.
I don't have an Xbox but i imagine the quality being about the same.
https://linustechtips.com/topic/885072-pc-build-help/page/2/#findComment-10930543
Ok thanks.. Im not sure why so many people are complaining about the audio.. I heard this board supports 7.1 audio.. which is amazing....
Thank you for clearing up some of the issues i have had when trying to make pc list. You have cut my cost down aroun $400 without loosing too much performance.. THANK YOU SO MUCH!!!!!
https://linustechtips.com/topic/885072-pc-build-help/page/2/#findComment-10930564
no problem, just be sure to message me with your streaming name + platforms so i can see you and my advice in action some time ;)
Good luck!
https://linustechtips.com/topic/885072-pc-build-help/page/2/#findComment-10930618
