Ram's prices got up again just before i was about to buy them... due to this i will have to get a lower quality one : HyperX Fury 16GB DDR4-2400MHz (HX424C15FB2K2/16)
with r7 1700 and asrock killer SLI , ama i able to overclock it to atleast 2800 ?
And is it even a good ram  ??
https://linustechtips.com/topic/885021-ram-picking-help-me-pls/
In general, Ryzen needs high frequencies, with 2600 MHZ Recommended and 3200 MHz being recommended. Ideally, you would you a dual channel v.s. a single channel configuration. However, the CAS latency does not really matter, but lower is better .
Therefore, I would recommend a kit a bit more like this here. Whilst Hyperx is actually a subdivision of Kingston and they do make a good memory, 2400MHz is not ideal for overclocking, however, it is still possible.
Perhaps, you may wish to look at this guide for Ryzen here .
https://linustechtips.com/topic/885021-ram-picking-help-me-pls/#findComment-10941237
On 1/12/2018 at 2:58 PM, GirvanaWantsBinnieBalls said:
will i be able to overclock it to atleast 2800 ?
Most ram modules can be overclocked 1 or 2 notches, so yes, 2800 should be possible. I have a 2133/ 13 hyperx kit OCd to 3000/16.
I'd aggree with fish_food, tho, Ryzen loves fast ram, so at least 3200... I found a 3000/15 kit which was priced amongst 2400/16 kits. People weren't buying it cause it was red, so I got it for cheap. Look out for deals like this.
My R2700XT build:  r7 2700 @4.1 Ghz max 65C - Sapphire Pulse rx 5700xt @1625Mhz 955mV 1300rpm fans, max 82C - Asrock B450 gaming k4 - Gskill Ripjaws 2x8GB @3200mhz CL16 - Be Quiet Straight Power E11 650w - Fractal Meshify C - EK-Kit S240 - NB eLoop 120mm PWM - Be Quiet Shadow Wings 140mm 1000rpm - Bitfenix Spectre LED PWM 120mm - Samsung 250GB 860 Evo - Seagate Barracuda 2TB
Peripherals:  Acer XF270HBbmiiprzx 144hz 1080p TN - CM Storm Quickfire TK - Coolermaster MK750 - CM Storm Reaper - Logitech G303 - Logitech G502 - Logitech G603
Audio:  Hyperx Cloud Stinger - Samson SR850 - Trust Screamer - Creative Gigaworks T20 II
https://linustechtips.com/topic/885021-ram-picking-help-me-pls/#findComment-10944687
