Hi,
So today i've gotten what i suppose are the updates for the spectre,meltdown issues on windows 7, but i've also read people get a pretty big slowdown on haswell cpu's like mine.
Should i just updated or what is the deal?
I'm kinda lost and dont know what would be best
Any help/opinion is appreciated
https://linustechtips.com/topic/884609-spectre-and-meltdown-question/
The big question is did YOU observe a big slowdown?  If not, no biggie and no need to update.  Most of this is being blown way out of proportion.  It's what we do in the tech community.  The reality is most of the performance degradation is within margin of error.
If you don't store any sensitive data on your PC, then you can avoid the update entirely. I would frankly suggest that, at least until Microsoft figure out what they're doing, since they've already pulled some of these updates for messing up older, mostly AMD systems, which didn't even really need the update to begin with. It's a good idea to keep an eye on https://www.askwoody.com/ for information on Windows updates in general, as he often catches the ones that cause problems.
11 minutes ago, Themostdead said:
Only read about it on the webs about the slowdown, and i do store sensitive and personal data on my pc yea, so i guess it's best to update?
Not using an AMD machine btw
Have you installed the update yet?
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
1 minute ago, Themostdead said:
Not yet
In that case, you should try using several CPU benchmarking programs and do a Before and After test.
So basically, i'd recommend benchmarking your CPU before using a few different programs and record the results and then do the same thing after the update is installed.
And then you can see how much of an impact there was. I'd recommend doing each test from each benchmarking app 3 times to ensure reliable results.
Just to be sure, the update windows has brought out for this issues gets installed via the windows update program right? its not a separate download or anything?
This.
While this is a Windows sub-forum, I'll say that on my MacBook Pro, these Spectre/Meltdown updates did not decrease my benchmark scores. I ran benchmarks before updating to High Sierra (Sierra to High Sierra is like Windows 8 to 8.1, not major upgrade), then with High Sierra and then finally with supplementary update including the Spectre and/or Meltdown fixes. Benchmark scores remained in the same range, +/- 2-5% which falls under margin of error.
macOS Sierra did not contain any of those patches at that time, only High Sierra did. Day-to-day usage hasn't changed either.
EDIT: It really comes down to what you are doing with your computer. If you are not doing any constant heavy lifting with the CPU, such as running databases on the PC, you really will not see any major performance degradation.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
3 minutes ago, jj9987 said:
This.
Mostly use for school/games/ work etc but some pretty intensive games, but thats more GPU specific
for Windows 7 and 8.1 it might be a separate download.
Check through Windows Update first.
Update it. if you experience a slowdown, either live with it, or upgrade your hardware.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
