https://www.asus.com/us/Motherboards/B250-MINING-EXPERT/
If i connect the AUXPWR connectors on this motherboard, do i still need to power the risers w/ their own separate molex/sata connector? I will be utilizing all 19 PCI-E slots with XFX RX 480s (https://pcpartpicker.com/product/9KX2FT/xfx-radeon-rx-480-8gb-core-video-card-rx-480m4bfa6
The Computer will be Powered by 3 Corsair HX1200 Platinum (https://pcpartpicker.com/product/f7L7YJ/corsair-hx-platinum-1200w-80-platinum-certified-fully-modular-atx-power-supply-cp-9020140-na)
Also if i do have to power each riser separatly will the PSUs have enough connector slots for 19 GPUs?
2nd Also... If i power each riser do i have to connect the GPU 6-pin connector to the PSU and does it have to be the same PSU as the one powering the riser?
https://linustechtips.com/topic/883454-power-what-else-to-put-here/
