Parts:
Cpu: Intel i7-6700k
Ram: Corsair vengeance 3000
Mobo: Gigabyte z270mx Gaming 5
Gpu: Evga ftw3 1080 ti
So I went ahead and downloaded the Intel Management Engine critical update utility off of the Gigabyte site. Ran it, and now I can't even hit post. I've tried removing everything but cpu and ram, tried clearing cmos, and even tried a backup i5-6600 and spare crucial ballistix ram, but still the same result. I am currently bootlooped before hitting post. Each attempted boot alternates between the DRAM and the VGA error lights turning on in the mobo. Anyone have any ideas as to what I can do? Really don't want to RMA this board.
print "Hello World!" ("Hello World!")
https://linustechtips.com/topic/882853-need-help-booting/
Well the BIOS is probably rekt, if Gigabyte has a flashing utility that you can run externally like ASUS then you can flash a new BIOS on it that way. Otherwise you will have to RMA
Builds:
https://linustechtips.com/topic/882853-need-help-booting/#findComment-10908531
8 minutes ago, SmashinMachine said:
USE the DVI Port annd PS2 keyboard. Or use the Intel GPU port....
No output for PS2. I've tried both the HDMI and display port coming off the Intel integrated gpu and still no luck
https://linustechtips.com/topic/882853-need-help-booting/#findComment-10908586
Method #1:
1. Shut your PC down (if you're reading this guide, than your PC isn't working anyways)
2. Hold the power button until the PC starts and shuts down again
3. Press the power button again, your backup BIOS should kick in now and should re-flash the main BIOS if there's anything wrong with it.
Method #2:
2. Hold the power AND the reset button for about 10 sec, than release.
3. Backup BIOS should kick in anytime soon now.
Can you try these methods above?
https://linustechtips.com/topic/882853-need-help-booting/#findComment-10908721
46 minutes ago, Airdragonz said:
Yea. Had only the mobo, cpu, and 1 ram stick.
Method #1:
Method #2:
And Does it work??
https://linustechtips.com/topic/882853-need-help-booting/#findComment-10908787
