Warning Point System
Solved by minibois,
You get a (or more than one) warning point(s) if you do something naughty. Usually warning points have an expiration date, or sometimes they are permanent.
I think they have set up a number that if you get more than whatever many, you get banned (either temporary or permanent).
Basically if you don't break the rules, like getting into fights you'll be fine.
