XP Meme Machine (Not sure if someone already did this)
OS: Windows XP Professional
CPU: AMD Athlon XP 3200+
GPU: NVIDIA Titan XP
Motherboard: Any compatible one I'm not sure
RAM: Any compatible RAM modules that's compatible with the motherboard.
Haven't check compatibility but I don't care.
https://linustechtips.com/topic/882468-xp-meme-machine/
As mentioned by @MrDrWho13, this is pointless because of missing drivers. This is stupid anyways.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/882468-xp-meme-machine/#findComment-10904982
No drivers
Austin Evans did this some time ago
https://linustechtips.com/topic/882468-xp-meme-machine/#findComment-10904984
Quite the waste of time.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/882468-xp-meme-machine/#findComment-10905015
Eh.. that's kind of an integral part for the system you described to work even in a basic sense.
1) Titan XP doesn't have windows XP drivers and really shouldn't for that matter
2) Titan XP only runs on PCI-E, I'm pretty sure Socket A and Slot A only uses AGP and even if there was a Socket A or Slot A motherboard with AGP it would be using a first-gen PCI-e which would likely be incompatible with the titan XP. Mainly not enough bandwidth and complete mismatch of generations.
3) the Titan XP likely doesn't have a legacy video BIOS booting mode, though I haven't checked. What I mean by that is that it probably requires UEFI to boot properly.
4) A plethora of issues that wouldn't even come to mind initially but you would definitely face.
5) This is about as funny as going into PCPartPicker, making a dual Xeon E7 system with 8 4TB NVME Pcie SSDS, 4 Titan Vs and posting on a forum saying you just made the best budget console killer ever.
My main desktop, "Rufus":
PC Specs:
CPU: AMD Ryzen 5 1600
CPU Cooler: Cooler Master MasterLiquid Lite 120
RAM: 2x8gb Corsair Vengence DDR4 Red LED @ 3066mt/s
Motherboard: MSI B350 Gaming Pro Carbon
GPU: XFX RX 580 GTR XXX White
Storage: Mushkin ECO3 256GB SATA3 SSD + Some hitachi thing
PSU: Seasonic Focus Plus Gold 650W
Case: Corsair Crystal 460X
OS: Windows 10 x64 Pro Version 1607
Retro machine:
PC Specs:
CPU: Intel Core 2 Quad Q9550
CPU Cooler: Stock heatsink
RAM: GSkill 4gb DDR2 1066mt/s
Motherboard: Asus P5n-e SLI
GPU: 8800 GTS 640mb, I swap between that and my 8800 GTS 512mb
Storage: Seagate 320gb right from 2006
PSU: Ultra 600W
Case: Deepcool Tesseract SW
OS: Windows XP SP3 32-bit, Linux Mint 18.2 Cinnamon 64-bit, Manjaro Deepin x64 (sorta)
Mac Pro Early 2008: Dual Xeon X5482s w/ 32GB RAM & HD 5770 running macOS High Sierra
More PC's
https://linustechtips.com/topic/882468-xp-meme-machine/#findComment-10905029
26 minutes ago, MrDrWho13 said:
I don't think there will be Titan XP drivers for Windows XP
23 minutes ago, Shreyas1 said:
No drivers
DRIVERS!?  Drivers are the LEAST of your problems.
There are no PCIE capable chipsets for Socket A CPUs.  You can't FIT a Titan XP into a Athlon XP board.
https://linustechtips.com/topic/882468-xp-meme-machine/#findComment-10905030
4 minutes ago, tjcater said:
Only issue I would see, is if there is a hypervisor with nesting support that can even run on XP.
I don't think so, because hypervisors required major additions in OS features in order to run when they started to become mainstream, which was after the introduction of XP. Hyper-V, for one, was only introduced in Windows Server 2008 (Seems like Vista might have it too). As far as I'm aware, Windows XP nor any of its service packs allow the use of Hyper-V. Besides, the performance would probably be terrible.
PC Specs:
Retro machine:
PC Specs:
PSU: Ultra 600W
More PC's
https://linustechtips.com/topic/882468-xp-meme-machine/#findComment-10905065
Just for fun I searched for 3rd party VMs that supported nesting and XP. Surprisingly I found out that it might be possible with VMware. The latest version XP supports is Workstation 10, which supports a feature called Virtualized HV (Which is what their docs say is required for a guest hypervisor). Buuut this leads to another possible issue: Virtualized HV support also needs the processor to have VT-x and EPT or AMD-V and RVI. Good news is that processors with sufficient ability appeared as early as 2010 from Intel and 2007/2008 from AMD. But in the end, this still might have the issue where it could need an OS feature not present in XP or it has another compatibility issue :S
Edit: @Legendarypoet
https://linustechtips.com/topic/882468-xp-meme-machine/#findComment-10905842
