24 pin broken? help
Go to solution Solved by paddy-stone,
1 minute ago, Berosar said:
heyyy!!! thats exactly what i have!!! so i hope it still works! the 4 pin is balls deep in and the 20 pin is like 98% but when you push one down the other side comes the 2% up
Ah OK, pull it all out, should be able to with a bit if wiggling and pulling at same time... then look how the connectors fit together when you have them out... then slot them together before putting them in the board, it takes a bit of practice sometimes, but it should be fine.
https://duckduckgo.com/?q=20%2B4+pin&iax=images&ia=images&iai=http%3A%2F%2Flib.store.yahoo.net%2Flib%2Fdirectron%2F20-4-01.jpgRP-600-PCAR_20+4_pin.jpg
You can see above the little plastic pieces on the 4 pin that get held down by the 20 pin.
I plugged the 24 pin in but it wasnt like, perfectly on it so i took it off and wanted to put it on again but one of them plastic squares on the cable was left behind in the plug. Is it broken now? can i get it out?the 24 pin still did fit in there and the pins were all up straight. idk what to do or if i even should do something about it.
https://linustechtips.com/topic/882226-24-pin-broken-help/
I'd think so. What PSU is this, by the way?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/882226-24-pin-broken-help/#findComment-10902702
GG PSU, and unless you can get it out, motherboard.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/882226-24-pin-broken-help/#findComment-10902731
2 minutes ago, Berosar said:
ill first see if it starts.... i really dont have money for this sheit
Well, how deep is it? You may be able to pull the piece out with some pliers, but if not...GG motherboard and PSU.
SPECS:
https://linustechtips.com/topic/882226-24-pin-broken-help/#findComment-10902744
Maybe a dress pin can be used to extract it. Using the head like a small hook.
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/882226-24-pin-broken-help/#findComment-10902760
It's most likely a 20+4 cable is all, the +4 part is held down by a couple of small plastic holders coming from the side of the 20 pin. Just make sure the +4 is in all the way and insert the 20 making sure the plastic holders are pressing the +4 down still. I'm surprised we still have these TBH in 2018, most PSUs now come with a 24 pin instead of the out-dated 20+4 pin.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/882226-24-pin-broken-help/#findComment-10902762
Actually re-reading your post I'm not sure if that's what you mean, lol - do you have any pics? or can you take soem so that people can see what you mean?
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/882226-24-pin-broken-help/#findComment-10902767
https://linustechtips.com/topic/882226-24-pin-broken-help/#findComment-10902771
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/882226-24-pin-broken-help/#findComment-10902812
didnt even have to take the plastic leftbehind out. just had to take it out, line the 4pin with 20 up and put them back in, the plastic leftbehind just fell back in place. perfection
https://linustechtips.com/topic/882226-24-pin-broken-help/#findComment-10902870
Yeah, I just meant so you could see how they fit together, so it'd help with the re-insertion... anyway glad you got it back in OK and everything's fine again :D
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/882226-24-pin-broken-help/#findComment-10905178
