Honestly, with a high end system, you shouldn't be feeling a huge difference. It just makes your CPU run without idling as much--like it runs at a higher clock speed even if it's not doing anything. I would go with high performance, because why not..? :P
"May your frame rates be high and your temperatures low"
I misread titles/posts way too often--correct me if I don't.
Main difference is the amount of power they use. Balanced is light while max is high consumption. Unless you live in area where electricity is super expensive or hard to get, just go with max. The difference is bigger on laptops when max drains battery much faster.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
