I’m considering getting a 1080ti, since I do a lot of work in Adobe Premiere, and my current graphics card (AMD R9 280) is long ovedue for an upgrade. My current setup is like so:
Intel Core i5 4690k
Corsair Vengance 8 GB, DDR3 1600Mhz
WD Blue, 1tb
Should I get the 1080ti, or should I buy something else, and have money for other upgrades, like an SSD?
https://linustechtips.com/topic/880753-graphics-card-advice/
1070 tops, will bottleneck.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/880753-graphics-card-advice/#findComment-10888335
Before you drop $750 on a GPU have a look here
https://www.pugetsystems.com/labs/articles/Adobe-Premiere-Pro-CC-2015-3-Pascal-GPU-Performance-840/
This is the 2015 version, but there is no difference in cards once you get to the 8GB 1070 and up.
https://linustechtips.com/topic/880753-graphics-card-advice/#findComment-10888385
Thank you! That’s actually extremely helpful!
https://linustechtips.com/topic/880753-graphics-card-advice/#findComment-10890182
