Triple Monitor Stand
monjanger
I have 3x Dell S2716DG monitors and have just been using the included stand for now. I want to clear up some desk space though, so I was thinking about getting a triple monitor stand. The problem is most stands can barely support 27 inch, and if they can they can’t be adjusted to a suitable angle. I was wondering if I should go with three single monitor clamps or maybe roll the dice and go for a ergo tech triple monitor stand.
Ergotech Triple Desk Stand with Telescopic Wings (100-D16-B03-TW) https://www.amazon.com/dp/B007BD0MPM/ref=cm_sw_r_cp_api_tt7sAb2QDTZAC
VIVO Single LCD Monitor Desk Mount Stand Fully Adjustable/Tilt/Articulating for 1 Screen up to 27" (STAND-V001) https://www.amazon.com/dp/B00B21TLQU/ref=cm_sw_r_cp_api_iw7sAb1MK99RJ
i have been looking into mounting 3 moniters and can not decide on the triple or single mounts, i want mine wall mounted so i think for me it will be the single's but the ergotech ones looks good, its expencive but good though
