Since I like making builds that I will probably never be able to make, I made a Micro-ATX build on PCPartPicker.  Any opinions on it?
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($209.89 @ B&H)
Motherboard: Asus - ROG Strix Z370-I Gaming Mini ITX LGA1151 Motherboard  ($183.39 @ OutletPC)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($204.99 @ Amazon)
Storage: Crucial - MX300 275GB M.2-2280 Solid State Drive  ($89.99 @ Amazon)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive  ($159.00 @ Newegg Marketplace)
Video Card: EVGA - GeForce GTX 1070 8GB HYBRID GAMING Video Card  ($529.00 @ Adorama)
Case: Fractal Design - Define Nano S Mini ITX Desktop Case  ($59.99 @ SuperBiiz)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($51.99 @ Amazon)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($89.89 @ OutletPC)
Monitor: Asus - VG248QE 24.0" 1920x1080 144Hz Monitor  ($253.99 @ SuperBiiz)
Keyboard: Cooler Master - MasterKeys Pro S Wired Standard Keyboard  ($115.73 @ Amazon)
Mouse: Corsair - Harpoon RGB Wired Optical Mouse  ($24.99 @ Amazon)
Other: Symphonized NRG 3.0 Premium Wood In-ear Noise-isolating Headphones|Earbuds|Earphones with Mic & Volume Control (Black Night & Hazy Gray)  ($49.99 @ Amazon)
Other: SteelSeries QcK Gaming Mouse Pad - Black ($9.99)
Total: $2032.82
Generated by PCPartPicker 2018-01-01 23:47 EST-0500
https://linustechtips.com/topic/880489-a-small-build/
1070 Ti???
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885896
if you probably won't be able to ever make these.....does our input matter until you can actually get the parts?
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885897
It could be planning for something he could save up for
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885903
sure but by that time he saves it could be completely irrelevant as something newer./better for the price might be available. I am fine to still give input, but personally I hate window shopping. I don't like to think about stuff I can't buy :(
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885907
But I would say that you should replace the 750 with a 750Ti. I would probably go with a bigger power supply to at least 600w. If nothing else, it would give you growing room in the future and you wouldn't be pushing your PSU less, which could help to extend the life of it.
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885909
750?
Why the PSU btw, it's fine.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885912
Same but I do that way too often haha.
I've got $250 to finish my PC upgrade so hopefully that works out; Micro Center Ryzen 5 1400s got sold out :/
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885913
Just now, SolidRedIron said:
I just don't want the GPU to be choked by the PSU
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885930
Total: $2032.82
Why a z370... cant overclock
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885933
That's all there is currently
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885934
Because Z370 is the only chipset for LGA 1151-v2
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885936
Well this is where I heard it from:
Ah... I thought you meant the PSU would bottleneck the GPU. Didn't think about it in a airflow way.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885938
*and for an upgrade path*
*Of only 6 more virtual threads*
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885942
I wouldn't buy a 1400, no point. At that price range intel would make more sense, unless your already on Ryzen in which case just get the 1600, much more worth it.
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885944
*For a core i5 9600K*
*pretty sure will be on different platform because intel f***s people*
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885952
Just out of curiosity, would you consider a different CPU?  $100 more will get you the i7-7700K which I think is probably a better "bang for the buck".
CPU: Intel Core i5-4460 3.2 Ghz Quad-core  Motherboard: Dell 088DT1  RAM: Generic Dell 2x4 GB DDR3  GPU: EVGA Nvidia GeForce GTX 1050 Superclocked  Case: Corsair Carbide Series 400C - White (with Cooler Master LED Strips)  Storage:  Seagate Barracuda 1 TB  PSU: EVGA 500 W1, 80+ WHITE 500W  Monitor: Asus VS247H-P - 23.6 Inch  Cooling: 3x Corsair AF120 and 3x Corsair SP120 Case Fans  Keyboard: Corsair K95 Platinum RGB  Mouse: Logitech G502 Proteus Spectrum (Corsair MM300 Gaming Mouse Pad)  Headset: Logitech G930 7.1 Surround Sound Headset  OS: Windows 10
https://linustechtips.com/topic/880489-a-small-build/#findComment-10885973
