I'm building my first PC and it's gonna be hardlined cooled (please don't waste my time trying to explain to me how I shouldn't custom loop for my first PC) so I really wanted sleeved cables. I already made a color combo and got everything ready from ensourced but I want to know what cables I need to get and what length. I will have an i7 8700k custom loop cooled, evga 1080 ti ftw 3 custom loop cooled, 4 ram sticks, 1 1tb samsung pro m.2, asus maximus x hero mobo, a 4tb seagate baraccuda pro, and most importantly an EVGA SuperNOVA T2 750W. Can you guys please go to the guy's site and tell me what to pick (evga type ?, which cables, etc.) and I will add my own color stuff and whatnot. All help is appreciated :)
Retrowave
Air cooled version of my first PC.
CPU: Intel Core i7-8700K
Cooler: Corsair H150i PRO
Thermal Compound: Thermal Grizzly Kryonaut Thermal Paste
Motherboard: Asus ROG MAXIMUS X HERO (WI-FI AC)
RAM: G.Skill Trident Z RGB 32GB (4 x 8GB) DDR4-3600 Memory
SSD: Samsung 960 Pro 512Gb M.2-2280 Solid State Drive
SSD 2: Samsung 970 EVO Plus 1TB M.2-2280 Solid State Drive
HDD: WD Black 6TB 3.5" 7200RPM Internal Hard Drive
HDD 2: Seagate Barracuda PRO 4TB 3.5" 7200RPM Internal Hard Drive
GPU: EVGA GeForce GTX 1080 Ti FTW3
Case: LIAN LI O11 Dynamic XL
PSU: EVGA SuperNOVA P2 1000W 80+ Platinum Fully-Modular ATX Power Supply
Case Fans: Corsair LL120
Fan Controller: Corsair Commander Pro
Set Up
  • Mouse: Razer Deathadder Elite
  • Keyboard: Razer Blackwidow X Chroma
  • Mousepad: Steelseries QcK Gaming Mousepad
  • Monitor: Asus ROG Swift PG278QR
  • Audio
    • AMP: Sennheiser GSX1000
    • Headphones: Sennheiser 58X
    • Speakers: Bose Companion 2 Series III
  • Oculus Rift + Touch 3 Sensor Roomscale Setup
https://linustechtips.com/topic/880332-sleeved-cable-help/
Well cables are easier to say once you have the motherboard and GPU in the case, then you can run a string from the PSU port to the place its going to go and add a couple cm
Builds:
https://linustechtips.com/topic/880332-sleeved-cable-help/#findComment-10884366
ok, so I'll wait until I have pc ready, can you just tell me what cables
Retrowave
Set Up
  • Audio
https://linustechtips.com/topic/880332-sleeved-cable-help/#findComment-10884371
Well I'd only get the ones that you can see, which will probably be the 24 pin, the EPS for the motherboard and then the PCIe connectors for the GPU. They will also need to be EVGAs style Ln the PSU side which I'm not sure what it's called
Builds:
https://linustechtips.com/topic/880332-sleeved-cable-help/#findComment-10884403
alright thanks :)
Retrowave
Set Up
  • Audio
https://linustechtips.com/topic/880332-sleeved-cable-help/#findComment-10884407
My first build was a custom WC Ioop, Just make sure you have proper tools for bending. I personally would suggest buying AlphaCool hand bending tool, which will make bending allot easier.
Link: https://www.alphacool.com/shop/hardtubes/accessories/20839/alphacool-acrylic-double-bending-tool-12-14mm-and-16mm-black
Assume you want him to build the cables for you?
You Need the following:
EPS (CPU) - you need 8 Pin Version, I believe your board only needs one.
ATX (Mainboard)
GPU (8-Pin) - You will need two of these both need to be 8-pin for FTW GPU.
Perf (Sata or Molex) Cables, He only makes Single & dual Sata & Molex cables.
Lastly I would just make sure you want paracord over PET Sleeving.
Also I would check out Mod-One.com They make custom PSU cables with both Paracord & PET (MDPC-X, Best Sleeving around). They are also very easy to get a hold of and very helpful. Ensource sometimes takes awhile before they reply to any messages. Most of my supplies come from Mod-One.com when I create my own custom cables.
24838955_190118704877222_385996253283588
Paracord (I don't work with much paracord since it's a pain, and personally PET just looks better, no risky of it shedding). Plus you need a threader to get wire/terminals through the sleeving. It's just annoying to work with.
20837825_1469643679790412_94807300935935
PET
Current Build: Project Frost
Gaming Rig Build: Project Ice Dragon
https://linustechtips.com/topic/880332-sleeved-cable-help/#findComment-10887388
Wow, thanks a lot. That was a lot of help and tips, really appreciate it :). Will check out mod-one and might ask for further help if I need anything, thanks
7 hours ago, Revan654 said:
Retrowave
Set Up
  • Audio
https://linustechtips.com/topic/880332-sleeved-cable-help/#findComment-10889301
